Old 03-15-2008, 07:51 PM
jeffast jeffast is offline
I kill more trannies then god
all i know is i drove it for a good 20 min, then let my sister drive it then my dad drove it and it runs fantastic. and i am still deeply confused, makes me wonder if their is untapped power in the eg33 that the ecu know about but doesn't make use of. If that makes any sense?
1991 xt6 eg33?
1993 gc track car
Old 03-16-2008, 09:22 AM
Speedklix's Avatar
Locker Link Solution
yeah, it is remarkable... Most cars let you know right away that something is wrong with the timing
added to the list of things to one day understand
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 03-16-2008, 09:29 AM
Speedklix's Avatar
Originally Posted by Trevor View Post
“6 volts trevor, i checked them yesterday before i posted this,”
I think he mentioned that it was in the ON position, not running.
I get 9 volts or less on many of the 12v sources until it is running.
-Mike
[SIGPIC][/SIGPIC]
Old 03-16-2008, 02:01 PM
It was not mention but one would assume that the engine was not running during the voltage testing at the coils. If the test was correctly carried out this surely indicates an absolute fault. The problem is that no tests have been definitive and the opposite non suspect cylinder bank should have been tested, by way of a direct comparison.
It is my contention that the tests in respect of the ignition must have been in error. Logical fact is involved, not mystical magic.
If you have circuits which are directly supplied from the battery and which measure only 9 volts or less when there is 12 volts at the battery, you have serious voltage drop problems.
Old 03-16-2008, 02:45 PM
Speedklix's Avatar
... yes one would! i should have stated, without a jumper wire or jumper box for that matter, either would suffice
I know you're not from here, but I have a "wal-mart" (cheap) battery with probably a collapsed plate and has been dead cold in winter
It keeps running though and I'm sure plenty of other people on the cheap have done the same... As long as it gets the car running, my 120amp alt handles the rest. Yes, I do have some issues... which is why I am systematicly replacing the wiring as I mess with it. I had some major issues that actually ended up being cracks in the maf wires like halfway down the loom... i'm more than 150% sure that I have wires in the same condition in plenty of other places... will rectify in due time!
-Mike
[SIGPIC][/SIGPIC]
Old 03-16-2008, 07:12 PM
Hi Mike,
I keep reading about all sorts of problems which do not plague me. All wiring and bits and pieces on my 92 SVX are perfect, as are those on the little 1971 FF1 Subby I took for a spin this morning. However there has been some rust, now repaired, in the door panels of the FF1.
In Auckland we have the sea east and west 10 - 15 miles apart, so are not blessed with perfect conditions. What the hell is in the air up your way? Is it globular warmed or something? Or is it that most cars lack a nice homely garage at night time.
Cheers and watch that wobbly plate, Trevor.
Old 03-17-2008, 03:57 PM
Speedklix's Avatar
mostly what they put on the roads...
don't know what causes our plastic stuff to degrade soo much quicker Acid deposition is all that comes to mind.
-Mike
[SIGPIC][/SIGPIC]
