#31
Re: Looking for manual AWD car
Before this got hijacked, the original request was really simple; "If you see something, let me know." I suppose suggestions on options are helpful, without pissing on other options, but, really, I just invited people to let me know if they saw something that fit the description of 1.AWD, 2.Manual, 3.Decent power, 4.Doesn't need major work and 5.Less than 125k miles.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
#32
CR didnt treat the X type badly (I know, Kim Jong Un is more creditable
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
#33
I have to say, this has been an interesting exercise. I will publish my findings when I am done. I think it will be useful to people.
On a related subject, does anyone know if the EJ22 can have the heads from the EJ25 placed on it? Are there extra sensors that keep such a thing from being possible? The thought is to take the more reliable 2.2L engine and make "Quattrovalvole".
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 07-20-2013 at 03:03 PM. |
#34
??????? You know that the 22 is a 4 cylinder and the 33 has 6?
#35
Holy crap, brain cramp. I mean the heads from the EJ25!!!!
#36
ej22 block with ej25 heads will work but compression will be lowered and youll have to swap in the ecu that goes with the ej25 heads and intake.
better option is putting and ej25 block between some ej22 heads to raise compression, then can just use the ej22 stock ecu and wiring harness etc.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
#37
Isn't the EJ22 already a four-valve engine?
Disclaimer: The above post is on the internet. |
#38
You are correct. I never had a subie with the 2.2. I had always thought they were 2 valves per cylinder but I must have been recalling the EA series. The reason for the original question was that I was wondering if a blown EJ25 could be replaced by a EJ22 and if using the EJ25 heads on it would be beneficial. I found the answer to the first question, which is yes, and especially if it is a 1995 EJ22 engine. Now I know that using the EJ25 heads would not be beneficial, if even possible.
#39
J
jc |
#40
Nevermind...not worth it
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 08-02-2013 at 08:30 PM. |
#41
Here are the results of my search.
First, on the subject of ratings, I found several options but CR was out due to its questionable methodology and the fact it is pay. Of the rest, four seemed worth investigating. I mentioned the pros and cons of each above. I gathered reliability data on several cars that met my original criteria of manual with AWD or limited slip FWD. I didn't gather data on every single car that met the criteria but I stuck with ones I liked, had heard good things about or had been suggested to me. The list included Subaru Imprezas and Legacies, Audi A4, BMW 330xi, Volvo S60 R, Jaguar X, Honda Civic Si, Acura TL, Nissan Sentra SE-R Spec V, Mazda Speed6, Infiniti G20t and I30t and others. I then took models and years for which I had data from all four rating systems and averaged over the four. Finally, I did a correlation of each system with the average. It did not surprise me which ones came out the best. The Reliability Index from Warranty Direct and the MSN ratings from Idenifix were best correlated to the average. The TUV ratings and JD Power ratings were not well correlated. I don't think the JD Power ratings are biased but they just don't look at cars when they have sufficient miles and years on them. TUV is very suspect. They are a German organization and, SURPRISE, the German cars seemed to rate out much better in their ratings than the others. As far as the cars were concerned, the Acura TL, Honda Civic Si, and Subaru Impreza did the best followed by the Legacy and the Volvo S60 R. Some select years of other models also came out above the "cut line" but, in general, the other models didn't do so well. And it should be noted that the Subies from the head gasket years didn't either. In fact, one thing I really like about the MSN ratings is that they tell you what the car typically fails for when it does. I wish they were a little more critical and had more resolution to their ratings. 3 levels isn't enough to catch certain minor issues or to catch when major issues are somewhat less frequent.
#42
Doesn't really help, but my Impreza wagon is for sale
http://i840.photobucket.com/albums/z...93705d9zzz.png |
#43
....Volvo S60 R, Jaguar X, Honda Civic .....
I would suggest that the Jag X may not be a good bet...suspect transmission known for early failure, "sealed unit". A Google Search will give more specifics. Just my 2 cents.. Craig |
#44
Yeah, like I said, it didn't make the cut.
#45
I just realized I never posted links. Here are some links to start with:
MSN/Indentifix: http://autos.msn.com/research/vip/Re...101953#VIP_TAB Warranty Direct/Reliability Index: http://www.reliabilityindex.com/reliability/search/300 TUV: http://www.anusedcar.com/index.php/t.../subaru-legacy JD Power (one example): http://autos.yahoo.com/newcars/reliability/select.html You can also get safety crash test ratings on the MSN site: http://autos.msn.com/research/vip/sa...101953#VIP_TAB
