Old 04-14-2010, 09:10 AM
NeedForSpeed NeedForSpeed is offline
Re: FWD vs AWD
Harvey are you saying the FWD final drive ratio is 3.700? I was not too sure on that.
Harvey is correct, the FWD US is 3.700
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 04-14-2010, 09:11 AM
Re: FWD vs AWD
Originally Posted by oab_au View Post
Yes Joe, thats as far as I know from the reports that I have read.
I think you can sum up the differences between the three types of drive, by looking at the way they handle a tight corner.
The FWD has to supply all the drive force, and all the change of direction force, so the front tyres reach their slip angle earlier, to under-steer.
The 4EAT depends on how much rear drive is applied. If the pedal is down, there is more rear drive, but if it is lifted, under-steer happens.
The VTD has most of the drive from the rear, but it also has the drive to the front to pull the wheels in the direction of change, the torque split will never drop below 36/64.
This amount of drive to the front wheels varies with the amount of steering, the tighter the turn, the more drive. The practical difference is with tight turns under throttle. The car just goes around with maximum drive, and steering grip.
Though, I might be biased.
Yes, you are rear-biased
Old 04-14-2010, 09:20 AM
Re: FWD vs AWD
Originally Posted by trueblue View Post
Has any one driven both an AWD and a FWD SVX? Does it make a difference in the handling and feel of the car in normal driving? I am sure AWD is more sure footed around curves and spirted driving.
If I use a JDM tranny to replace my slipping one it will be FWD only because of the different gear ratio used in Japan.
Any info would be apreciated.
Harvey is correct is saying that no way can you do this. If you installed a US AWD transmission of a different ratio, my experience is that you can do this, for a while anyway.
If you install the fuse when running a US-style (non-VTD) transmission, essentually, you make the car front drive. When we swapped our 4.111 trans, we ran the fuse with the rear 3.545 rear diff still in the car. However, this is not a great idea, unless careful. We drove the car up and around a steep drive, and broke a sprag.
The VTD power to the rear can not be disabled by the fuse. The importers have many transmissions from japan, most ARE the US style. Get one of those if you must, but know that a VTD will not work as you suggest.
Keep us posted
Old 04-14-2010, 11:32 PM
trueblue's Avatar
trueblue trueblue is offline
Send a message via AIM to trueblue
Re: FWD vs AWD
Keep us posted [/QUOTE]
Thank you all for your input. I see my idea was invalid, I have come to my senses and will look for a 4.44 conversion. I just have to find someone to install it. I hate going to a dealer for service but I may have to for this. Do you think a Subaru dealer can handle the rear end transplant?
[SIGPIC][/SIGPIC]Kenyatta
The farther backward you can look, the farther forward you are likely to see. -Winston Churchill
My baby: 94 lsi
My fast baby: 2001 Suzuki Marauder
My new baby: 2010 Subaru Outback
Old 04-15-2010, 05:14 AM
Re: FWD vs AWD
Keep us posted
Thank you all for your input. I see my idea was invalid, I have come to my senses and will look for a 4.44 conversion. I just have to find someone to install it. I hate going to a dealer for service but I may have to for this. Do you think a Subaru dealer can handle the rear end transplant?[/QUOTE]
Ken,
A good transmission shop would be better for the rear end swap, and would be good for the transmission too....and probably a little cheaper than a Subaru dealer.
Make sure you get a 98-back tranny, the newer ones with the spin on filter aren't a direct swap.
