Old 10-17-2009, 04:48 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Re: NO MORE CLICK click CLICK START..ONLY START!
I just bought a relay and installed it. Took about 15 minutes. My car starts every time now
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-17-2009, 06:37 PM
BoxerFanatic's Avatar
Ok... I just spent an hour under the dash of my SVX looking for this daggum thing... and I didn't even see it.
I saw an orange relay and plug, that I put back on it's mounting tab, as it was hanging...
I saw a rubber covered sort of relay screwed to a point under the steering column. But only three leads... didn't look like the right thing.
Lots of plugs, lots of wiring under there, but I didn't see a bosch-style relay.
I just went back and looked at Eric's posted pictures.... and it looks like it is near a white sliding linkage assembly... just to confirm, that is around the top of the brake pedal, and the white linkage is the hood release, right?
Or is it on the gas-pedal, and HVAC side?
I suppose tomorrow, I should take back the 4-pin relay, and get the 5 pin relay, anyway.
It all gives me an excuse to put on the new ignition light ring, and a better-condition steering wheel shroud, anyway.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 10-17-2009, 06:57 PM
SomethingElse's Avatar
word words wording
mine was on the gas pedal hvac side...Thunder Tom said its supposed to be mounted to the steering colum.
Eric
Old 10-17-2009, 09:59 PM
ok...
I'll have to take another look.
The bit that was screwed to the steering column looks like a relay, with three pins, not four or five... although it had a metal mounting tab, which could have served as a ground, instead of a fourth pin for ground.
The odd thing is that it was covered in a rubber square sleeve, with a slot at the top for the mounting tab to come through, and just the electrical plug coming out of the other end. It almost looked weather-proofed or something.
It had a Mitsubishi/Subaru part number on the rubber sleeve, but I didn't jot it down. It is fairly easy to get to, so maybe I'll take it off, and snap some pics tomorrow.
I did take it down, and disconnected it to investigate... then put it right back. The car did start a bit easier, afterward...
BTW... what is the little footwell light bulb supposed to attach to down there? it was just hanging on it's wire, and I didn't see a place to fasten it to...
Old 10-18-2009, 07:53 AM
Tim's Avatar
Tim Tim is offline
Mine was mounted to the steering column. Its on the left side of the steering column if you are looking at it from the outside of the car.
It's on the right side of the steering column if you are underneath the dash lying down.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-18-2009, 08:15 AM
yt yt is offline
the three pin is for your blinkers/hazards. Don't mess with that one they are fragile.
There is a 4 wire harness going to a 5pin relay connector. Yes it still uses 4 wires but the relay must be the 5 pin style
Old 10-18-2009, 04:00 PM
immortal_suby's Avatar
Thread Killah
Ah - so that is what I destroyed when I did the heater core last weekend.
I was wondering what it did. It did not like to still be connected when I dropped the steering column. A little super glue and solder and I patched her up. Must have done a decent job, my signals all work.
Well, that doesn't explain why my airbag light is on now. I was hoping that little gadget was what did it.
Locker Link
2015 BRZ Limited 6MT
Old 12-05-2009, 11:38 PM
bcpianoman bcpianoman is offline
Gotta love this site!
This thread just saved me a whole pile of heartache and expense. I had this same problem and, with the information in this thread, I fixed it an 15 minutes. Before I found this thread I had planned to replace my starter when it wasn't the problem at all.
Thanks to all who contributed.
Old 12-05-2009, 11:42 PM
Re: Gotta love this site!
Eric helped me out with this back at the Pumpkin Carve Meet in October at OT's and I haven't had a click since then
Over the summer I replaced the ignition switch which helped to reduce the clicking to an occasional problem, but this has eliminated it completely...
Old 12-06-2009, 07:55 PM
Maybe this thread should be made a sticky for all to easily find in the future...
Old 12-06-2009, 10:16 PM
At the very least a reference, or better still a link, should be included within the how to stuff.
Old 12-20-2009, 02:23 PM
dave-o dave-o is offline
Originally Posted by SomethingElse View Post
Well it finally happened to me..click click click yadda yadda yadda why wont this ****ing car start!.....after tracing the wiring diagram and drawing out the circuit I began to do a simple voltage drop test in the most conspicuous area....THE INHIBITOR RELAY!!! GUESS WHAT!!! BAD INTERNAL CONTACTS...VOLTAGE DROP!!!
Ok sorry I got a little CAPS happy
replace relay...start start start start start
US models only, so our non us members with non us spec SVXii could not assist....we suck..before adding relays do yourself a favor and replace the bad one first.
Inhibitor relay + inhibits starting = fail.
Thanks SE!!! saved me a bunch of troubleshooting!
Old 12-20-2009, 03:13 PM
Very handy thread, second that this should be kept somewhere handily found.
my car has been starting every time since. Big help in the reliability department.
Thanks, SVX World Network, and SomethingElse, in particular.
Old 12-20-2009, 05:22 PM
Reference most certainly should be be included within the how too stuff.
Here we have a fault located and fixed, rather than the application of a band aid. The fitting of a slave relay is a means of overcoming a defective circuit, but when the fault has not been located and fixed, future trouble remains in the waiting.
Old 12-21-2009, 07:49 AM
RSVX RSVX is offline
Network Design Administrator
Consider the request submitted to those who can make this happen.
Life is a game. Play to win.
