#31
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
#32
well it looks like tom nailed it, the timing belt appears to be off i am out of time to continue pulling the covers today. the left cover is off and the hash mark is pointing straight up, the right bank it's pointing about thirty degrees tword the center of the motor. but this was looking with a mirror with the cover onyl partially off, so i couldn't get a clear view. but that was what it looked like to me more tommow when i pull the fans and timing cover.
1991 xt6 eg33? 1993 gc track car |
#33
Your post 26 stated --- you mean the belt it's self? thinking it might have skipped a few teeth? no i havent, but if the belt skipped wouldn't it run like crap full time? its the first 5 minutes after you reset the ecu where it runns and pulls like normal, that confuses me if thats the case. If the above statements are correct, ![]() ![]() When you refer to resetting the ECU, it is presumed you mean codes and the diagnostic system. ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 03-13-2008 at 08:33 PM. Reason: Post 24 |
#34
and when i said reseting the ecu i meant when i removed the battery cable to change the alternator
#35
Your post No 1 stated ---- all three cylenders on the right side are not fireing i can unplug the coils and it makes no differance. the codes come up as misfire cylenders1,3,5, My post 16 --- Before you start jumping to conclusions and messing up your loom. Why not check for battery volts at coil plugs 1,3 & 5, using a preferably a test light or meter? Tom, post 23 --- so do you have 12v to all coils??? Your post 24 stated --- when i changed the alt the car ran perfect for the first 2-3 minutes i drove it then it started missing on and off again, i'm really stumped. Your post 26 stated --- you mean the belt it's self? thinking it might have skipped a few teeth? no i havent, but if the belt skipped wouldn't it run like crap full time? its the first 5 minutes after you reset the ecu where it runns and pulls like normal, that confuses me if thats the case. My post 31 advised ---- Over to you to carry on as suggested and to test and confirm coil voltages.
#36
ok, thank you for your advise i'm gonna finish pulling the timing covers first, because the cams appear mis-aligned.
#37
well, the left cam was pointing straight up, and the right cam was pointing straight to the right, tomorrow i'm changing the belt i will report my findings as to the condition of the idlers. or if it is any thing obviouse that caused the problem
#38
I very much doubt that the timing is out on the basis of logic, as you have several times stated that the problem is intermittent. This would require the belt to slip and then regain a perfect setting after a period of time. So near an impossibility as to be absolutely ruled out of the equation.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 03-14-2008 at 11:52 PM. Reason: NB added |
#39
#40
#41
here is what happened the only time I have messed up timing... thought I killed it.
i remember jeff being a bit younger than me when I met him, but that was a few years ago... o wait he'd still be younger than me
![]() ...yeah, you know I've done a bunch of t belts on subies too but I still mistakenly used the neutral arrow when I blindly looked at the service computer which clearly points to the face of the sprocket and not the hash mark on the crank's tone... so TDC for cyl #1 = all cyls aligned ![]() Slapped the crank pulley on... Started it, sounded GREAT!!! Revved it kind of high, still awesome! So I shut it off reassembled everything topped oil, rad with coolant and extra in the overflow (impatient) first hill I came to the car turned into a stuborn dog, downshift, downshift, and okay, there we go. I had to use whatever gear would keep me between 2100 and 2200 rpm with VERY little throttle to get it back. 47-51 degree ignition advance! ![]() Too lazy to fix it that night, I pulled the svx out of the shed and drove it home instead. Next day, car starts up great again you can't tell there is anything wrong with it. Drove great right around the corner, revving and everything... things seam to run amuck only when the engine gets hot. Timing fixed, car was perfect again.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? Last edited by Speedklix; 03-15-2008 at 07:53 AM. Reason: fixedited da spellzing |
#42
Jeff, the hash marks are meant to line up with the corresponding hash marks on the rear timing covers... They are out on angles to each side so if one is straight up in the air, the other should be laying flat... Line them up with the hashes on the timing covers and go from there
Tom |
#43
...exactly, don't assume, and don't always use the "generic" instructions
![]() ...check out the how-to! the knowledge on this site is your best reference for eg33 tech
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? Last edited by Speedklix; 03-15-2008 at 08:08 AM. |
#44
fixed, aligned the timing belt, and she's running like a champ.
i still find it odd, that it would run fine for the first minute or two , then run like crap, that confuse any one else?
#45
“my sisters car randomly developed a giant missfire, all three cylenders on the right side are not fireing i can unplug the coils and it makes no differance. the codes come up as misfire cylenders1,3,5,” “6 volts trevor, i checked them yesterday before i posted this,” “when i changed the alt the car ran perfect for the first 2-3 minutes i drove it then it started missing on and off again” “its the first 5 minutes after you reset the ecu where it runns and pulls like normal,” Which confirms that the engine was OK for up to 5 minutes and when under load. ![]() Stumped is the word and the gods are not playing fair cricket. ![]()
