Old 07-31-2007, 09:54 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Don't do it, you'll void the warranty!!!!!
1995 Subaru Svx L / AWD
Old 07-31-2007, 11:21 AM
Originally Posted by dcarrb
You have to remove the entire panel. Two screws hold the front edge of the interior door panel to the door. They're exposed when the door's open. Once you have all the screws out, pop the bottom loose and lift the whole thing upward, then unplug the 2 power leads (one is for the switch cluster and one is for the door courtesy light). Two or three screws hold the 4-switch assembly to the inside of the door panel; it's easy. The only minor hassle is lining-up the door lock when you go to replace the door panel. Use a magnetic-tip screwdriver to replace that little screw underneath the door handle.
dcb
Open the door and take out the 2 screws on the front edge of the door panel, near the door hinge.
There is another screw located under the door handle, hidden behind the plastic plate which justs pops out with a small blade screwdriver.
There are also 2 more screws hidden under the felt mat inside the door armrest. Just peel it away and expose the screws, These are the mist important ones as they hold the entire armrest to the door frame. You cannot remove the panel with these screws in place.
