Old 12-04-2006, 11:04 PM
htyei's Avatar
htyei htyei is offline
SVX Animated Icon Guy!
Send a message via ICQ to htyei Send a message via AIM to htyei Send a message via Yahoo to htyei
Took it to a mechanic, and sure enough it appears to have been combination of the MAF sensor, and a slow / intermittent LH oxygen sensor.
Man, new MAF sensors are expensive!
Henry Yei
htyei@svxwrx.com
1992 Dark Teal LS-L w/o spoiler "OLIVIA"
http://www.svxwrx.com
Old 12-10-2006, 01:02 PM
htyei's Avatar
So I decided to clean my MAF sensor first, and soaked the thing in vinegar and water (ran out of vinegar) overnight. Stuck it back iin, now my car isdleing at 1.5k rpms instead of 750rpms. I get only one code
12,
I forgot how to clear the codes, and what 12 code means, since the svx-iw.com appears to be down at the moment. Anyone know off the top of their head?
Henry Yei
htyei@svxwrx.com
Old 12-10-2006, 02:38 PM
12,
12 = Abnormal signal from the starter switch. Doesn't have much to do with your idle. The ECU may take a few cycles to set the idle speed. It may come good.
Old 12-10-2006, 02:57 PM
htyei's Avatar
Hoping for the best, I'll be dropping down to pep boys to grab a standard paper air filter. I've heard the K&N oil from their filters may foul the MAF sensor, and I'd rather not do it again!
Henry Yei
htyei@svxwrx.com
Old 12-11-2006, 12:40 AM
alohanjv alohanjv is offline
Fill it up with 101octane at shell. Go on the highway at night, or on a track if you can. Open it up. Not recomended if you dont have good tires,AWD,brakes, etc...
Old 12-11-2006, 01:57 AM
htyei's Avatar
Seemed to drive great for after an hour. Idle rpms staying around 600-750 like before. After that I reset the ecu and error codes by draining the battery.
I started having rough idling and stalling again.....
Henry Yei
htyei@svxwrx.com
Old 12-11-2006, 12:14 PM
Sorry about that. I'm having some trouble with my ISP at the moment but hopefully will have that taken care of soon.
Old 12-23-2006, 03:49 PM
htyei's Avatar
I finally got my used MAF part and am about to install the ting. I checked my codes again after several episodes of engine stall. Now I only get
a code of 12. (after cleaning the previous MAF)
Henry Yei
htyei@svxwrx.com
Old 12-23-2006, 08:15 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I also get code 12 on my car. I don't know why? I have no problems starting the car.
Old 12-23-2006, 08:18 PM
htyei's Avatar
If we knew what code 12 meant, that would help . I am a bit confused on why the codes are always changing. Perhaps I do have an electrical problem after all. The new used MAF from a 97 is in, I hope my problems disappear!
Henry Yei
htyei@svxwrx.com
Old 12-23-2006, 09:44 PM
AJ4U2's Avatar
AJ4U2 AJ4U2 is offline
code 12 is the starter circuit.. I had to unhook my negitive terminal off the battery and let it stay over night, hook it back up in the morning and all was good.
Old 12-24-2006, 10:08 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Originally Posted by JoAnn merkur
I am having the same problem. car stopped in the middle of the road , but restarted without a problem. A few weeks before it was starting on 4 cylinders every day, had that rectified. But the engine light came on yesterday and its in the garage. They say they can't find anything, and asked me if I could show them what happens. I told them to take it for a drive and find out for themselves. As expected nothing happened.
omg, my car had has the exact same thing when first
starting it in the am.. Has been doing it for like 2 yrs now.
btw, whats the fuel ECU look like or where is it located ?
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 12-24-2006, 10:13 PM
I believe cleaning the maf with vinegar is a good idea
but just this last yr at SEMA K&N addressed the myth
of their filters causing problems
this link has a little info on about it
http://knfilters.com/news/news.aspx?ID=517
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 12-24-2006, 10:15 PM
When my car did the same thing your car does, I could
put it in nuetral and it would start back up.
After you start it again, if all is clear and you feel brave
try just nailing it and see what happens up to like 60 or so..
I found a few times my car would take off, and fall on its face
like it was starving of fuel, ..spark seemed to be fine.
But its still anyones guess.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 12-27-2006, 03:31 PM
htyei's Avatar
After a couple days, I beleive I can call my MAF installation a success. (off a 97 subaru svx) I haven't felt any hesitation and the engine has not stalled.
I still get check engine code 34, but that is probably another problem alltogether.
Now my latest issue is someone broke the rear passenger window to grab my labtop bag, only finding a bunch of gym clothes inside
Henry Yei
htyei@svxwrx.com
