Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 04-29-2006, 01:45 PM
TheRightWingSVX TheRightWingSVX is offline
Send a message via AIM to TheRightWingSVX
How about instead of precats, small glasspacks into a Y that leads directly into the stebro resonator and then to a magnaflow muffler. Woud this take care of my buzz??
'92 Subaru SVX
Moda 1-Silver five-star rims
ECUtune Stage 1
SmallCar Shift Kit
K&N
Iridium Spark Plugs
All Mobil 1 synthetic oils
Almost 160,000 miles and never ran better!
Old 04-29-2006, 02:12 PM
mbtoloczko's Avatar
sans SVX
It will help, but may not entirely eliminate it. Depends on how long the glasspacks are. I still think that someone should try making one of the pipes leading into the cat longer than the other. I'm thinking that a 4-6" difference should get rid of the resonance.
Mychailo
Visit my locker
Old 04-29-2006, 05:11 PM
How would you make one longer than the other?
'92 Subaru SVX
ECUtune Stage 1
SmallCar Shift Kit
K&N
Iridium Spark Plugs
Old 04-29-2006, 07:15 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
I agree ...I think that's why aftermarket headers for subarus look so weird and definitely don't seem to be equal length: http://cgi.ebay.com/ebaymotors/02-06...60459915QQrdZ1
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 04-29-2006, 07:27 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
One word of caution when putting anything in the system in front of the secondary cat....don't put anything that would "flake" pieces out into the exhaust flow (i.e. glasspacks) which would then foul the cat. You'll want to stick with resonators to be safe.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-29-2006, 07:47 PM
I can see what you mean, but they are all different lengths now. They all end up at the front of the third cat. The No.1 cylinder length is about 11" longer than No.6. This is to spread the resonate rpm over a wider range. If they are all the same length, they all come on frequency at the same rpms.
Old 04-29-2006, 09:19 PM
mbtoloczko's Avatar
sans SVX
Yeah, but adding another six inches to one side will make an even greater difference. The only drawback that I can see is that it will take away some of the "porsche-like" sing at high rpms. It will probably sound more like a V8 mustang exhaust.
If anyone has access to welding equipment, it should be relatively easy and inexpensive to test the idea.
Mychailo
Visit my locker
Old 04-29-2006, 10:25 PM
How about soomething like this to substitute the pre-cats- http://www.classicchambered.com/classic/products.html
'92 Subaru SVX
ECUtune Stage 1
SmallCar Shift Kit
K&N
Iridium Spark Plugs
