#31
excellent!! a lot of people have talked endlessly about pulling the weight and running the numbers, but nobody has actually stepped to the plate and done it. great to see someone is seriously approaching the project. I think the EJ33 is perfectly suited for a racetrack application and am eager to see what it's capable of doing without being restricted by all that extra weight -adam |
#32
Keene, NH- Totally Cool! I almost moved there two years ago. The decision not to is one I still regret. Of course, I wouldn't have met my SVX....
#33
Where is the rest of the wight hiding? SUBFRAMES!! I would be a prohibitive as getting custom glass made but it would save mucho weight if you got some forged aluminum subframes, control arms, and spindels made for it, also replace the brake componets with some aluminum bits.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
#34
Check this out for the weight of each window.
http://www.subaru-svx.net/forum/show...eight+of+glass If you were to remove ALL the glass, you're only talking about 70 lbs. not counting the windshield. Also, the rear decklid is surprisingly light, only like 15 lbs or so, if I recall correctly. Stephen Last edited by elninoalex; 12-28-2003 at 09:27 AM. |
#35
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX) Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting. Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well. You can tell the lack of craftsmanship by the wrinkles in the duct tape. |
#36
![]() good luck with your project! ![]()
Alan 1987 928 S4 (Black) SOLD! ![]() 1997 SVX LSi (Ebony) SOLD! ![]() 2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD! ![]() 1987 928 S4 (Black) SOLD! ![]() 2005 Forester XT Premium (Crystal Gray Metallic) SOLD! 2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+] 2015 Outlander Sport 2.4GT AWD (Mercury Gray) 2013 G37xS (Obsidian Black) |
#37
Has any one put aftermarket seats in there SVX to shave some weight and giive some support so your not sliding around on the seat. The stock ones are almost dangerously not supportive.
#38
Now I have a huge problem with remarks like that. I think the SVX seats are the most comfortable and relativley supportive ones out there. Just the leather one are slippery.
#39
There horrible for me I slide into the door and center consel, and have to hold my self by the steering wheel. They are very comfortable tho and great for long trips, because they acculy have the backe support I need.
#40
Regarding aluminum subframes- This car has no frame. It is a uni-body. The stamped sheetmetal roof, sidewalls, and floors create all the structural engineering completely by themselves. It is a truly beautiful design (speaking as one who has seen almost the entire stripped skeleton and who has an appreciation for great engineering!).
Aluminum control arms, spindles, brake components, etc. are truly works of art and perhaps worthy of the SVX. They may improve performance (better handling, braking, etc.), but will probably not reduce weight much. These components are also stamped sheet metal pieces (uni-body type suspension components). Some actual weights for reference (yes, I have actually weighed these items): Driver seat (leather with electric controls)- 68 lbs. Passenger seat- 49 lbs. Rear seat bottom- 13 lbs. Rear seat back- 24 lbs. Factory type spare tire- 28 lbs. Factory wheel complete with tire, balanced and inflated- 47 lbs. (Note only a 19 lb. difference between those meaty real wheel assemblies and the goofy temporary spare. Those wheels are fairly light.) Standard type battery- 31 lbs. Back glass- 20 lbs Rear 1/4(stationary) glass- 5 lbs Rear 1/4(moving) glass- 3 lbs Rear window regulator- 4lbs. Front(moving) glass- 8 lbs Entire AC system (less ducts)- 30 lbs. Bumper core- 28 lbs. PLEASE LEAVE THEM ALONE!! Entire sunroof assembly (including motor, cables, tracks, wiring)- 29 lbs. Hood- 46 lbs. Entire trunk assembly (including lifters, hinges, lights, reflectors, and wiring)- 37 lbs. BELIEVE IT OR NOT!! So- reasonable mods: Find some light weight seats you like (potential 87 lbs.), ditch the spare (28 lbs.), and ask your significant other to walk. Come on back to this forum and brag on the 115 lbs. you saved. It should net you approximately 1 tenth of 1 second in the 1/4 mile. Where the heck is the weight?? It's the PACKAGE. You're driving a lot of car. AWD. 4 speed electronic auto trans. 6 cylinders. ABS. Airbag. Electrically operated everything. Sound system. Incredible engineering from bumper to bumper. Lighter weight cars simply don't have all that stuff. Note that the STI weighs in at 3263 lbs. Great performance can actually weigh a lot. Drag racing rule of thumb is that 100 lbs. equals about 1/10 second in the quarter mile. You've got to really chop up this car to gain speed through weight reduction. Suspension mods will pay off more, better tires, nitrous if you are so inclined, perhaps a 5-speed. Let's not cut up too many SVX's. Ours is a school project that was saved from the crusher. But nobody's cutting up the one I drive! ![]() ![]() ![]() ![]() |
#41
Um- thats why they call them sub-frames and not just frames
#42
I'm familiar with the term subframe referring to a portion of a frame, ie: the front section of a camaro or mustang often grafted into older hot rods. You are referring to suspension components. It's just semantics, and doesn't really matter. Aluminum or other machined or billet components (or subframes) will not reduce any significant weight from the existing stamped and steel components.
#43
OK just checking
![]() ![]() How much does and empty shell of a unibody weigh? Anything added to that can be of a weight savings.
#44
I added about 25 more pounds to my SVX by eating like a pig since Thanksgiving. I'd better pump up the tires on the driver's side by 2 psi.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net ![]() ![]() |
#45
I'm not looking to gut the car totally and make a race only car. It is my daily driver, but like fatboyfsx said (even if he was off on some of the numbers) there is some weight to be lost without sacrificing luxury. And to the cynics that are convinced i have a 300 lb stereo set up, NO i don't. I buy cars to drive not to rattle apart with so much bass my eardrums bleed. My goal is to drop somewhere in the 100 to 150+ pound range. For the number crunchers out there losing 150 lbs and adding 75 hp puts the svx at roughly the same power to weight ratio as a trans am. Talk about shocking someone who was sure they were going to win.
