#421
Here's a whole mess of pictures from machining the power steering pulley. This power steering pulley is 6 ribs to match the supercharger which it shares a belt with and of course the crank pulley I made. It is also smaller than the factory pulley to keep the correct ratio with the smaller crank pulley. As I had mentioned earlier the splines and shaft onto which the pulley fits required having a broach custom engineered and made for us.
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 01-27-2006 at 02:22 AM. |
#422
Aw man, how friggin cool is that??? I may just sell my soul for a stage 3 just for the sweet ass aluminum PS pulley!!!!!!!!!!!!!!!!!!!!!!! Very nice Mike
Tom |
#423
This project is coming along so nicely. And that's one sexy pulley
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
#424
I've been looking at that last set of pics and wondering how you made that pointy star design in the PS pulley.
I'm just guessing, but is that ribbed rod like a file of some sort and just kinda oscillates up and down until it punches through? It seems to be smoother near one end and jagged towards the other.
#425
That ribbed rod thingy is what is called a broach. Broaches do not oscilate. They cut their pattern in one push or pull. This broach is a push broach. The way they work is each row of teeth removes a little bit more material than the last one. They are solid carbide and obviously very sharp. A keyslot broach like the one that we used to cut the keyway into the crank pulley is a reasonably priced tool. A splined broach like the one we used to cut the splines for the power steering pulley is a custom engineered extremely expensive tool.
I believe Mr. Fu did not notice that the broach has a taper to it with increasing depth of "teeth"...
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$ |
#427
Here are some pics of the new oil plugs with the bolt holes for mounting the alternator bracket. My engines have socket head oil plugs so I've unfortunately never had the opportunity of holding the hex head versions to see if they can be drilled and tapped for bolts. These are made from scratch starting with 6061 1" hex stock. I kind of wish I had made the out of steel because I could have threaded them in a LOT less passes. Threading to a shoulder has to be done at low speed so you don't run your cutting tool up into the shoulder. To get a clean finish on aluminum at slow speeds you have to remove very little material. So these short little things I had thread up to a shoulder took me about 50 passes each removing only 1 thousand at a pass. They are drilled 25mm deep and tapped to accept 8 mm bolts. In the last picture you can see the supercharger belt installed as well.
#428
No I saw it. I thought it worked kind of like an inside out cheese grater. Makes sense now. What I said earlier now makes no sense. These things happen. Mighty impressive fabrications.
#429
The alternator bracket came out really well. It's very sturdy and alignment is perfect without any adjustment. The tensioner is built into the bracket and has an inch of swing which gives two inches worth of belt length movement. The belt comes in tomorrow.
With the two idlers on the supercharger/power steering belt we get excellent wrap of all the pulleys and large range of tensioner movement. By changing the location of the power steering idler we can make it so that we get the tension we want with the tensioner pulley near the end of it's range of motion. If the belt ever stretches all we have to do is loosen the tensioner up, move the power steering idler in some, and retension. This maxumizes the wrap on the supercharger pulley. It's overkill and we don't even really need the 2nd idler but hey why not? Tomorrow I do the bypass valves then she's ready to test and finish (finish meaning paint and anodizing) just in time to install onto mike's car. |
#430
trip progress
Well I made it to Savannah, Ga last night. I made it from Dover, De in 9 hours. Not quite sure how. It should have been 11 hours to here. I used my Marriot points for a free hotel room (thank you Coast Guard). I'm packing up now and should be in Tampa by 2pm. I do believe I will be going to Bush Gardens tomarrow. I get in free!! Ya!!
#431
-Chike
#432
After noticing that the wire terminal lug on the alternator comes off and that I'd be able to rotate it I got into what turned out to be a fruitfull but long days work. The alternator bracket revision yesterday put the alternator lower and left of where I really wanted it to be. I had settled on this because of a clearance problem between the wire lug and the oil pan. By grinding the alignment bump off the lug and rotating it around and putting a dent in the front of the oil pan I was able to fit the alternator centered and up higher so that it's not the lowest thing on the engine. It is now a little higher than the headers. It took a few trials to get it so that a dent in the alternator lined up with one of the bolt heads that holds the bracket on but now that it's done it will be easy to replicate. Now that I have the measurements the fabrication of this bracket is actually easier than the last one. I want to pick up a slightly longer bolt than I had in the shop for the tensioner so that it goes all the way through the block at full tension but otherwise it's done.
Before you ask why there's an oven in the shop, it's for curing the powder coated parts. |
#433
Wow, you know you have really got me thinking about this. When wil the 2nd batch be making a run??
Tom |
#434
Thanks Tom, the 2nd batch will be right after the first batch. It's 6 oclock now though so I don't want to think about the next batch. I want to get a few hours sleep.
The bolt for the alternator bracket wasn't available in town so I had to make one. No pics of that...it's a bolt. I got the IAC mounted and have pics of that. It pipes to same place it used to be mounted on the bottom of the throttle body. I'm in the process of fabricating the mounting for the supercharger bypass valve. Space is ultra tight so ...fun. |
#435
I got the bypass valve mounted today. That means prototype #2 is now done. We were planning on doing the install tomorrow but I'm thinking it will work out better to do it Friday after a good night's sleep. I still need to cleen up the shop from the fabrication work, powder coat the parts, and get the software ready for Mike's car. I can do that tomorrow and get to bed at a reasonable hour.
It's bedtime for me. 3:30 is better than 6...making progress.
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 02-02-2006 at 02:03 AM. |
