#361
Now that the car sat over night and had time to cool I've pulled a spark plug and inspected it and sent pics to the tech at ngk I talk with. The insulator is perfectly chalky white so we aren't anywhere close to being in danger of fouling the plugs. The center electrode isn't greatly discolored so it isn't running too hot as is and the ground strap has a lil carbon on it that's chalky white showing that it's burning off propperly again showing the temp is right for the setup we ran yesterday. Since we seem to be running a good deal richer than what will give the most power especially at higher rpms we are going to rejet to lean things out. By leaning out things will get hotter and since there isn't any danger of fouling the plugs we are going to go with a plug another step colder. I just pin the order for the bkr8eix plug which should come in friday. I'm also going to get a bottle heater. Our nitrous bottle pressure was a little low yesterday (850 psi) which would have added to our problem of being too rich. This will leave us running again on saturday or sunday so look for the new #'s then.
I'm going to try some new gear selection methods and see what we can do about handling the horsepower better at launch. I was looking through the service manual at the transmission section and the difference between 1st and second gear is considerable but I'm going to try launching in second with the manual button on nonetheless and manualy shift into 3rd when it feels right. If I'm reading the diagram of the shift patterns in power mode correctly it doesn't shift into 4th at wide open throttle until you are well above 112mph/180kmh. This means if I can launch in second gear with no traction loss but still push that big a gear ok we'll only have 1 shift to go through from second to third. Hopefully the manual shift is quicker and then we can finish in 3rd gear. If this works ET time should be greatly improved. If I have to launch in first the first gear change isn't until 55mph. In this case I will try launching without the nitrous armed, with the manual button on and first gear selected. I will then arm the nitrous and it will engage after we're rolling, then manualy shift to second and third when it feels right. If this proves to be the best route we should be able to launch with the nitrous armed off the line after installing larger tires. |
#362
Michael,
My '92 speedo read 125 mph when it shifted into 4th at full throttle. It will be a fine day when we need fourth in the quarter. How do I know? I was on a long straight country road when I pulled up behind a Harley at a stop sign. Pulling away from the sign, I went around him at full throttle. He went around me like I was parked. I lifted at 125 with the Harley well in front. Where's my supercharger? |
#363
'92 LS-not-so-L: the "SVreX"- Saved from a crusher, an SVX racer built by home schooled students for less than $2000 (including purchase price). 13.8 second 1/4 mile. Autocrossing monster!! '92 LS-L Claret: '01 RS 4:11 5-speed, Exedy organic, lightened flywheel, and Koni/ GC |
#364
I have no idea how to convert the rear wheel calculators for AWD, but its clear to me they would be extremely inaccurate. I think the car has an 80/20 torque split on hard acceleration. That would indicate it acts more like a FWD car than a RWD.
Yes, the car is significantly lighter- by about 700 lbs. It's not a street driver. I forgot 1 other modification- we were running 215/45/16's. They look a little dumb, but offer improved acceleration due to the smaller diameter. NO wheelspin. 2.044 60' times.
#366
That was not an attempt to brag, only to agree that the 1/4 mile time should be improved at 101 trap speed.
#367
I will start a new thread. A buddy of mine pointed me towards a DSM website that has come up with their own formula to calculate AWD horsepower from 1/4 times and trap speeds - the formula can be switched around to calculate ET and Trap Speed.
-Chike Quote:
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 04-21-2004 at 02:50 PM. |
#368
Actually, i just found the thread and it's the same online calculator that is commonly used for rwd cars.
#370
I was told the formula was slightly different, but if it is the same then I was misinformed.
If RWD cars have a drivetrain loss of 15-20% (depending on transmission) and AWD cars have a loss of 20-25%, can that formula be modified in any way to accomodate this? -Chike
#371
#373
I'm like 90% sure the SVX doesn't weigh that much. From all the sites I've seen, it says the SVX weighs about 3525lbs.
- Rob |
#374
I'm going to cornerbalance my car next week on our scales, I'll give you guys an exact figure on my '94 LSi's weight.
#375
The advertised weight that Subaru posts, is dry weight...no gas, no oil, no water, no washer fluid, no brake fluid...I guess you get my point, motorcycles do the same thing, but by the time you add all the fluids, a bike weighs 10-15 pounds more than the advertised weight, and a car holds a lot more fluids. This would explain the differance in weight of a driven car and the manuf. advertised weight. Just my thoughts on it.
