#316
The SRT-4 is a very impressive Neon but it is still a Neon which means it is a FWD dodge. It is limited in that sense. I am also surpirsed dodge tells people to power shift, thats rediculous. Clutch won't hold up long that way though. |
#317
not to be an ass.. but could we have some verification of this powershifting cue from the neon manual... i can't see how this could possibly be true
not anything agaisn't you phast.. i just.. haven't seen it. or heard of any manual saying that ever maybe non-dodge manual?
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
#318
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock |
#319
Wait, i never thought of that. Can we do it? Ya know im gonna go try it right now.
#320
#321
#322
#323
bahhh... the work involved would not make it worth it... period.. plus i think the 3000gt motor is transversly mounted.
and hp is directly related to torque, if we're keeping the same redline. but anywho. The 4eat wil l be able to handle it.. you'll just need a second radiator just for tranny fluid. if you wanted a fully drag SVX.... i'd try to see if you could get a looser torque converter made, to raise the stall. this would allow you to "brake torque" the car at launch, and with a 4000 RPM stall.. it would really get things moving. again... look for radiator sized cooler if not for drag.. i think the 6speed would be more fun
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker Last edited by drivemusicnow; 12-15-2004 at 08:08 AM. |
#324
if it is the case, I will keep the 4EAT, install a big cooler for it and turbo charge the car..........
#325
#326
phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#327
Best of luck with it Phil.
As our mechanics say here in Ireland: "Keep the shiny side up and the oily side down" Joe
#328
Good thinking Batman
Compared back to back, the auto tranny will always be a little slower out of the blocks than a manual tranny. Because it can absorb some of the high early torque, it will be less prone to breaking differentials and so on, acts as a buffer and protects the metal parts from shearing. If you have enough power and torque, and not enough empathy for the mechanicals, you can break anything. However, I hope to produce reliable power and torque which will not overcome the standard drive train. It could turn out to be an affordable upgrade when developed, who knows? Fingers crossed, Joe
#329
halfway down under calibration features, the best i could find for you online but comes with the stage 2 manual. phil
#330
I'm a close friend of SVXtacys and have been present through the entire project, since he first got the car in the summer of '02.
He's dealt with some seriously tough blows dealing with fabricators, naysayers, and whiny *****es from square one. I'd be lying if I said that it wasn't satisfying as hell to have been able to help bring something like this to life, and prove the naysayers wrong. But he made it happen, he did the research, he did the majority of the fabrication, too. He loves & hates that car just like it was his wife. He's had girlfriends, parents, and friends harassing him all along the way as to why he's been putting so much effort into this car and he's seriously had more than ample opportunities to move on to something else. He's paid his dues and done more research on this project than could possibly be considered sane. We chose an AIC because we didn't want to mess with timing maps by pulling/adding fuel with an SAFC, which at the time of this projects conception was the only option for controlling larger injectors short of a full standalone. The stock timing maps and timing advance remain normal, and the additional fuel is never there when not under boost so the car has zero driveablility or low speed problems. Personally, I find the SAFC to be more of a hack and only advantageous when you've got an factory boosted car that hates giving you timing advance and has little if any aftermarket ECU flashing/adjustment available, such as a DSM. When timing advance is your enemy, the SAFC could be deadly, there's dozens of Turbo MR2 owners running larger injectors on SAFC's with the stock ECU that fried motors because of the part-throttle timing and fuel maps. Being that the MR2's run 8.5:1 compression and have a much larger fuel system, I wouldn't want to try to make a 10:1 motor with a 57 trim happy with an AFC while fighting n/a timing maps. For this SVX, the AIC was literally the best choice possible, short of a standalone. Possibly better than a standalone since this was a street car not a race car, any anyone that's actually tuned a standalone will tell you. Its a real pain in the ass to make a tune from scratch. Setup is a pain in the ass too, with crank triggers and cam angle sensors, etc, and regardless of what anyone likes to say you're *never* done tuning it if you're daily driving it. Sure, it takes maybe an afternoon tops with a wideband to get a nice WOT map with good power and clean a/f's but its that part-thottle, decel, etc that takes forever to make happy on a standalone, and then you need to be worried about being too edgy with it based on the weather & elevation, etc. Even most piggybacks with lots of adjustment (emanage, split second, etc) can cause similar driving issues if you deviate too much from stock maps. Since SVXtasy wanted a daily driven car for the most part, the Stock ECU w/pulled timing and an AIC is pretty much the best solution possible as long as we don't have problems from the high compression, and thus far we have not (yet ) It also happened to be the most cost-effective, especially considering the price of Nismo 555cc injectors. At our altitude (5500ft elevation) we've got a lot more elbow room because of the thinner air, but what almost stopped the project dead in its tracks was the lack of a way to adjust ignition timing. The 87 octane map was a bit of a godsend for the reduced timing advance, just to be on the safe side since he was doing this on a stock 10:1 compression motor. We could have gotten away with 5 psi at this altitude with no timing retard on premium but once he went to sea level there would be problems. He wanted this car to be driveable anywhere and trust me, he's done his homework to do exactly that. He's hit so many speedbumps in this project that I can't even remember them all. I'll tell you though, after the shop got done with his IC piping and we first went over there to try boosting it, I would have killed to have a picture of the look on his face after we hit 9 psi. The mixture of excitement, fear, and outright stress was absolutely intense. The engine sounded like nothing else I'd ever heard as it was ripping up to the rev limiter. The closest comparison is a Turbo 911, but the 911 doesnt sound that pissed off.. Since we were having wastegate and spooling issues and the boost sensor for the AIC wasn't picking up any manifold pressure, we used a Greddy mechanical boost gauge that I had lying around to troubleshoot. I was holding the gauge in the passenger side and He was driving, and once he hit 9 psi around 4k he hit the 6500rpm rev limiter so freaking fast we both thought that he'd broken something. We started the car and it purred like nothing had happened... The altitude here probably saved the engine. But after we got it back to the shop, he was still shaking with fear and excitement as he walked back to his daily driver Legacy. The second time boosting after working out the wastegate issues and having good boost response from around 2500-3000rpm, the wastegate springing for approximately 5 psi seriously woke the car up. But to quote SVXtasy after I told him we'd hit about 4-5psi: "great! now we need a boost controller!!!" I can't wait to see what this car does once we get the AIC tuned and fill it with some 101 and run 9-10 psi on the stock timing advance, if I can talk him into doing it that is.. Once the AIC is tuned I think he's shooting for 8 psi on pump gas with the 87 octane map, and at this altitude that should be fine (and fun!). I think the Impreza 2.5 RS trans will explode first, He thinks the engine will fry first. Either way, I'm almost as excited as he is to think about how much fun its going to be to freak out WRX's and Evos around here.... I hope that holds you all over until the full writeup comes from the man himself.. -Jeff |
