#286
By real numbers you mean dyno or track time #'s or do you mean on the camshaft profiles? I posted the complete plots of the cnc data on the camshaft profiles earlier in the thread. These cams obviously haven't been installed in any cars yet since the matching valves do not come in until next week.
Getting the Heads done.
This would be great. Now I can knock out the bottom end once we work out the bearings.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#288
I just meant HP / Torque numbers . Ok , so youre waiting for valves ... I'll wait for numbers !!
Nightmare is the name of the car... |
#289
Glad to hear it Mike thnx for the call man
tom |
#290
did a lift vs crank rotation chart ever get made?
#291
Plots were posted of lift vs crank rotation earlier in the thread.
I posted in Tom's engine build progress thread. I already have the high silicon aluminum rod bearings in stock. $100 a set. As soon as you have your crank out we can get it done.
They shipped the valves today.
#294
Sweet. By the way, you never gave me any info on where to ship the crank and stuff, or has that not been set up yet?
#295
I just got back to tampa tonight. I'll hopefully get to my email tomorrow.
Valves are in. Fedex is picking up the valves and springs tomorrow and off they go to you.
#297
actually, they went out usps today.
#298
thanks Mike... Looks like as soon as I can get that diagram and the valves from you, I can get that motor together in short time
Tom |
#299
Valves
Mike:
You mentioned that the intake valves will be just over 92mm long the exhaust valves will be just over 92.6mm long. What are the dimentions of the stock valves? The new valves look great. Great job sourcing them. I'm glad you went with inconel on the exhaust valves. They should hold up well. Are you recommending that we install new stock external springs? I was thinking of doing that just to be on the safe side. Anything else we should consider changing out with the valve change? Thanks Chuck D.
#300
The factory valves are:
intake: 90.00mm exhaust: 90.85mm Just re-use your old outside springs. The only thing you should need are new valve stem seals which are included in the overhaul gasket and seal kit. Quote:
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 07-17-2007 at 12:09 AM. |
