Go Back   The Subaru SVX World Network > SVX Main Forums > Wanted or For Sale
Old 01-24-2003, 10:49 AM
kuoh kuoh is offline
Actually, the rubbing has already trimed away most of the lining that was in the way, but I don't like that solution, which is why I ordered a new lining. I'd much rather get wheels that fit correctly.
KuoH
Old 01-24-2003, 10:58 AM
Lowered SVX
kuoh.........
I have no experience with aftermarket 16" wheels. What I and Dayle know is that if you increase in wheel sized 17,18, 19 the only thing you have to be aware of is that you can not go wider than 7.5 inches and the offset must remain 38mm or above. With those parameters in place the wheels will not rub.
"Too much fun to drive!"
Old 01-24-2003, 03:34 PM
When I first got my SVX I was getting some rubbing when going around corners or over larger bumps with the stock size wheels/tires. However, this was rubbing on the INNER lining. I have since remedied the situation. Anyone else have that problem?
Old 01-24-2003, 06:43 PM
Dayle on another note, do you have a source for hubcentric rings for the SVX? I'm not quite ready for the bigger wheels, but I do have a 16" that I like very much but I'm getting too much vibration at highway speeds. If I can find the right rings for them, they would be great.
KuoH
