Thread Tools | Rate Thread | Display Modes |
Re: Starter, power steering pump, ac compressor, engine parts, etc
Make me an offer. It fits in a Priority mail medium flat rate box so shipping will be $12.65.
It sounded like you might have a pending repair so I wanted to make sure you got it asap. I have another pump here that the tank is definitely not bent on if you want to swap it.
I'm going to start posting this stuff on ebay. If anyone here wants to get any of this stuff while I have it msg me here and I'll cancel the ebay auction for you.
http://www.ebay.com/itm/231687188111?item=231687188111 |
I found another ac compressor and power steering pump behind another box today.
Here's the compressor: http://www.ebay.com/itm/231687613760 |
here's the power steering pump: http://www.ebay.com/itm/231687617859
This one is clearly marked as remanufactured. It looks pretty new to me. |
Thanks
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
Mike
by "undersize" do you mean the bearings will actually accommodate cranks that have been cut/polished down from their original mains/rod sizes? thanks Bill
Yes, undersize means the ID is smaller to fit a crankshaft that has been ground.
Mike
These vvvv std size aluminum rod bearings .025 undersize aluminum rod bearings .050 undersize coated aluminum rod bearings .025 undersize coated main bearings Bill
#28
Sorry, I messed that all up.
I have one set of Clevite's made in Japan aluminum standard size rod bearings. I only have two .25mm undersize uncoated aluminum rod bearings. I have one set of .50mm undersize coated aluminum main bearings. I have one set of .25mm undersize coated aluminum rod bearings.
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 09-16-2015 at 02:50 PM. |
#29
The ac compressors, camshafts, ring and pinion, and the std size aluminum rod bearings are still available
all the power steering pumps are sold and the starter is selling in an ebay auction ending tomorrow the coated bearings are sold as well
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 09-19-2015 at 05:55 PM. |
#30
ac compressors are sold.
Still available: Stock SVX intake camshafts std size aluminum rod bearings 3.545 ring and pinion |
