Old 11-20-2013, 01:43 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Re: iPod for stock radio adapters
So far:
1. intelisevil
2. Sean486
3. theflystyle
4. Abyss
5. ShaneHobson
6. WhatIsThisIDont
Still hunting for some kind of DIN connector switch. If anyone knows of one, let me know!
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 11-20-2013, 02:35 PM
Wonder if you could have a wire run from the cd player that you could couple with the Aux cable when you wanted the CD input?
Old 11-20-2013, 03:39 PM
**Ewie**'s Avatar
**Ewie** **Ewie** is offline
Aussie in enemy territory
Def count me in.. I've tried the radio one which is a pain, and currently using the old cassette adaptor... average at best.
Old 11-20-2013, 04:59 PM
bishop bishop is offline
I could go for a standard aux input, the only reason I wanted to upgrade the stock stereo is for aux in but if you can make the connector I'll buy one.
Old 11-20-2013, 10:34 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
I'd be down had I not installed a new double DIN unit last March.
There should be some kind of DPDT switch that would allow you to switch between the CD and AUX input.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 11-21-2013, 05:02 AM
I'd take one..... just let me know when you're ready to make them..
Old 11-21-2013, 09:21 AM
theflystyle's Avatar
how possible to have a dual input cable?
meaning the cd player would still be able to work when powered on but when the aux device is powered off.
1994 SVX LSi
2008 Legacy 3.0R
Old 11-21-2013, 10:07 AM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
I'll take one!
I haven't used my radio or CD player for 2 years, everything is through my iPhone, which unfortunately is currently fed through a cassette adapter.
My cassette adapter is era-correct though... it is the original one that came with my all metal construction 1991 Sony Discman (complete with shock abosorbing mounting plate). Anyone here collect antique electronics?
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 12-29-2013, 06:22 AM
B 4 You, are you still going to make these?
Old 06-07-2014, 11:56 AM
michael's Avatar
michael michael is offline
What Potholes ???
+1 if you make them, I picked up an extra parking light switch to put in place of the coin holder to switch aux on/off. Also considering adding a button next to the security switch or this.
Wanted: Steering Wheel
Old 06-07-2014, 11:18 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Count me in - you can save postage by shipping mine to Shane Hobson (maybe other Kiwi's ?).
We can split the postage cost Shane ?...
Old 06-08-2014, 01:36 AM
ShaneHobson ShaneHobson is offline
Probably don't want one now, 80% through fitting my new Sony.
I would have preferred keeping it original.
See what happens when they become available
Old 06-08-2014, 11:40 AM
SURTEESS's Avatar
ok - still count me in though ....
Old 06-08-2014, 01:28 PM
I'd be out at this point, I'm tapped since having the bodywork done.
