Old 02-18-2013, 04:44 PM
Re: Can`t read power steering trouble codes
Originally Posted by Kiss Me Deadly View Post
Well, firstly, i`ve solved the code problem - it was a poor connection on 7th injector Steering lamp doesnt become anymore)
The next bad news is sometimes its really hard to turn the steering wheel on low speeds. How to find out which one pressure control valve in the pump now? Is there any resistance difference between them or label?
If the rack is a RPM sensitivity type, both pumps should give full pressure at low rpm. If it still has the Speed type, it will stay full power at all rpms. Some other fault must be causing the hard steering. Does it get easier if you increase the engines rpm?
Old 02-27-2013, 10:24 PM
Kiss Me Deadly's Avatar
Kiss Me Deadly Kiss Me Deadly is offline
Send a message via ICQ to Kiss Me Deadly
Its hard to turn the steering wheel only at low speeds. I`ve noticed after WD-40 sprayed on cardan joint it becomes softer
Subaru SVX LSi `95
