Old 04-25-2012, 07:18 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Re: Another wiring question.
Originally Posted by B 4 You View Post
I already made this switch press-able, but I can't figure out how to get a switch in there. How did you do it?
That was a complicated project. I had to make some little metal runners for the switch contacts to touch and solder wires to them. Then I had to shave out the shape of each runner in the plastic switch body. I basically copied the same design as the actual switches. It's definitely more work doing it this way than with a shift lock button.
These are the little runners before I glued them in.
This is finished, before I put it back together.
but nobody has one available anywhere and it seemed to be too much of a hassle.
Did you check with Nate or somebody that has a lot of parts cars? You literally only need the plastic oval piece. If you could make one out of something else, then you wouldn't even need that. I used a generic push button on-off switch that I had from a CD player or something, and just glued the plastic oval to it to make it look stock.
I cut out a small slot in the top of the plastic button for an LED, but I haven't decided how to power it yet.
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 04-25-2012, 09:19 PM
I did mine the lazy way. used that switch housing but I just stuck a switch in it:
Who has a pic of the steering wheel mounted switch, I like that one the best I think.
Old 04-25-2012, 10:04 PM
Although I have not done this mod, I always thought that using a foot--activated, floor mounted headlight switch (like in the older cars to control high beams) would be ideal.
No cutting or drilling, completely reversible, and the ease of not having to move your hands from the wheel to activate. It would also be easy to run a separate LED anywhere to show when it was activated.
Just a thought.
