Old 04-10-2012, 12:33 AM
smc smc is offline
Re: STI suspension
Hmm. I just found a stock STI suspension for sale for relatively cheap on craigslist. I may have to pick it up and test to see exactly how they fit. Ill call the seller tomorrow and see if they are still for sale.
Old 04-10-2012, 10:51 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: STI suspension
So from what i'm getting at a stock Sti suspension will bolt in by drilling new holes for front/rear, welding new tabs, and adding camber bolts to align it right?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 04-10-2012, 07:26 PM
smc smc is offline
Re: STI suspension
05/07 STI suspension. 3 bolt holes per strut tower. Camber bolts for correct alignment. Top bolt hole on the front strut to knuckle mounts needs to be elongated. Tabs welded to the suspension for the front swaybar, and the swaybar linkage lengthened to reach. The rear strut to knuckle bracket needs to be widened aka bent outward a little to fit. The bolt holes for the rear will line up correctly, so no other mods will be needed in the rear.
Old 04-11-2012, 05:52 PM
Re: STI suspension
well stock 05-07 sti susp is almost non existant to find for sale here in aust (like most things)
what are your thoughts/opinions on these options ?
http://www.ebay.com.au/itm/BC-Racing...item19cf72fde6
http://www.ebay.com/itm/GODSPEED-05-...082932&vxp=mtr
http://www.ebay.com/itm/GSS66-1USS2-...8c7852&vxp=mtr
http://www.ebay.com/itm/MEGAN-RACING...f8e936&vxp=mtr
http://www.ebay.com/itm/GODSPEED-05-...b1ae2f&vxp=mtr
http://www.ebay.com/itm/YELLOW-DPS-C...1e8505&vxp=mtr
http://www.ebay.com/itm/BC-Racing-BR...2c3f3c&vxp=mtr
Old 04-11-2012, 06:11 PM
Re: STI suspension
Nice That doesn't seem to hard to do. I'll add this to the list of things needing done
Seth
Past subies:
Other toys:
Old 04-11-2012, 08:03 PM
smc smc is offline
Re: STI suspension
You can order just the stock struts for a STI for relatively cheap from the dealer. Then toss on a set of quality coils and your good to go
As for your e-bay dampeners:
Hmm. They are all pretty decent for the price range.
When possible, look for an inverted shock design, like what I have.
Keep in mind that in a macpherson strut design like our cars, the struts are a stressed member of the suspension. When you corner, all that stress is transferred from the wheels to the struts then to the chassis. I dont know about you, but I dont like the thought of all the cornering stress of our heavy cars being pressed upon a 1/2" shaft that is the strut rod.
In an inverted design, the strut body itself slides into the mounting sleeve and takes all the stress of the suspension.
Adjustablility in the compression / rebound is a great thing to have, if your tuning for the track. If its a daily driver, its not really necessary. You would be surprised how a couple clicks can turn you from understeer to oversteer in a hurry. Or a balanced well handling car, to a twitchy turd on the street. Choose wisely
Old 04-11-2012, 09:07 PM
Re: STI suspension
yeah im not sure how relatively cheap that would actually be here seeing as everything is basically 2.5x the price you guys can buy the same part for there
i will go up to the dealer and ask them how much they are
and if i was to get stock sti ones , i would still need to get camber adjustable strut tops, right ?
and quality coils ... any suggestions for them ?
ah ok so i take it none of those are the inverted design ?
just searched "inverted struts" on ebay and this is the ONLY listing that came up
http://www.ebay.com.au/itm/NEW-OEM-S...item1e6d1aea02
the adjustability thing would pretty much be for show and once it was set i would not change it ...
ever
Old 04-11-2012, 10:00 PM
smc smc is offline
Re: STI suspension
You can get coils for tarmac or gravel for the stock struts. The gravel coils are a fair bit stiffer than the stock SVX rates, but allow for longer travel. The tarmac. Well, it depends on the stiffness you want. A general rule of thumb in terms of track suspension: keep the suspension firm yet supple, and run big swaybars. If your springs are so stiff *like mine* that your tires loose contact with the road surface, then your loosing traction and negating the use of the suspension in and of itself.
The best coils on the market:
http://www.swiftsprings.com/products-ss_spec_r.html
Give them a call, tell them what your looking to obtain performance wise and they can get you just what you need.
Old 04-11-2012, 11:08 PM
Re: STI suspension
Stealership has to ring an sti stealership to get prices .
So what parts of stock sti struts are used
Front :stock housing and strut with different springs and adjustable tophats ?
And rear: stock housing , strut and top hat with different springs ?
Old 04-12-2012, 12:39 AM
smc smc is offline
Re: STI suspension
The strut assembly's front and rear, sti tophats, the nuts for said tophats as they are a different thread than the svx bolts, and camber bolts for adjusting the alignment. Thats it
Old 04-12-2012, 01:18 AM
Re: STI suspension
well thats where im confused . The parts guy told me they dont sell complete strut assemblys. They sell it separate instead eg housing , shock , spring , Hat. Hes a bit of a cranky old ba%$&rd and doesnt like to actually do much research . (ive had to deal with him before for other parts ) . Maybe il just call a subaru hotline and see what they say and get part numbers
Old 04-12-2012, 02:44 AM
Re: STI suspension
i might have found a full set of 06 sti struts , are all subaru camber bolts the same or do they need to be 05-07 sti ones or svx ones ?
also found a set of 07 rear sti struts (15000kms on car being wrecked )
that i can get pretty cheap
Old 04-14-2012, 08:10 PM
smc smc is offline
Re: STI suspension
So far it seems that all the subaru camber bolts are the same. Ive used a set from a wrx on the rear of my old svx.
Old 04-15-2012, 12:37 AM
Re: STI suspension
Ah ok cool . Good to know
Old 04-17-2012, 03:06 PM
Jvan Jvan is offline
Re: STI suspension
Will the STI top hats also work with Koni inserts? I have installed the Koni's and need to replace the top hats. I understand that I will need to drill new mounting holes but will I still need to install the camber adjusting bolts?
