Re: any 5x114.3 8in wide fit?
I also like the clean look of the FOX RACING FX1 wheels. Available in diameters from 15" to 18"
you can, but you'll have to be selective on tire size, there was a member who had 18x8
i'm running 17x7.5 and im' fine
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
These are 18X8 with 235/40R18 and have plenty of clearence all the way to the bumpstops. This is both wider and taller than stock in the tire. The rim IIRC is a +48 offset and looks like you could make it work with a 40 offset if you were conservative on tire selection as I tried a 8mm spacer in the front briefly. This is why the older mustang rims fit decent. The current Mustang GT seems to have switched to a deeper offset so these rims should be even better. Just have to watch as they have some seriously wide versions. |
I really like those how much do those run?
XT6wagon: I was looking at some old svt cobra rims that were 17x8 do you think those would fit?
Jared 1992 dark teal SVX LS |
they might, a previous poster said these fit and I've seen photos of SVX's with them.
http://cgi.ebay.com/ebaymotors/05-09...item19c50fe473 |
If you do some searched you will find members have used a variety of wheel sizes (diameter and width) and tire sizes. I've used up to a 8.5" wide wheel (48mm offset) and could probably have fit a 9" wide version IF the offset were correct. An 8" wide wheel should fit wihout issues if the offset is between 40 and 50mm. You must also be cognizant of your tire size when combined with your wheel size. Tires will rub first. Tire size (width) with no fitment issues should be between 225mm and 245mm. With the correct offset wheels, 255mm width tires have been used with no issues.
Disclaimer-This is not a blanket statement of endoresement to any wheel/tire combo in the sizes above. You must choose what you are comfortable with and if they don't fit it is on you to make it work or deal with the issues. You may have to trial fit some wheels if you are concerned. I've used wheels and tires on my SVX from 15"x7" (NOT a typo) to 17"x8.5" with tire sizes from 205mm to 245mm wide on the street to autoX courses with no fitment issues.
Down to none Last edited by wawazat??; 06-28-2011 at 02:27 PM. |
so it seems that i will have to do a trail and error type deal thanks everyone! Jared
custom wheel spacers. Given tractor rims have a bolt pattern nearly the size of the stock rims outer diamiter.
More Mustang wheels, Dayles car I believe.
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
Down to none |
