Old 12-07-2008, 08:06 PM
Re: Our EG33 GC8 Swapped RS..
Originally Posted by Blenderhead View Post
You said more displacement, but I don't see where you say how you did that. Is the motor a stroker or the block sleeved and bored, or what? Part of the reason I ask, is that I was looking at the different bore/stroke ratios on the different flat-6 motors, and it looks like putting a 3.0 crank into a 3.3 block would give you a 3.5L engine, and I was wondering if the cranks share the same journal sizes and if something like this had ever been done. If anyone knows the answer to this, please let me know.
There is no way a EZ30 or EZ36 crank will fit in a eg33, as the EZ motor is a lot shorter front to back.....
Old 12-07-2008, 08:28 PM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Stock stroke, but custom 100 mm pistons. New displacement is 3534 cc's.
Bob Légère
EG33 Impreza tweaks
Old 12-07-2008, 09:40 PM
Hondasucks's Avatar
Subaru Technician
I'm curious about that intake setup, would be awesome to make that work on an SVX. I'd also be down with that DIS setup you are using, might not be enough room for it in an SVX (I wonder if they make aftermarket coil-on-plug coils that would fit...)
Also, needless to say, I know that car has got to be insanely fast! Those are quick enough with the 165 HP NA 4 banger in them... Please tell me that has a manual transmission behind it!
1986 VW Jetta
Old 12-07-2008, 11:40 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
Originally Posted by EFI Logics View Post
Custom 5 speed gear box W/ RA Gear set and Cusco Tarmac Center diff from Fizz Autosports
yep, it does
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 12-08-2008, 10:18 AM
Blenderhead Blenderhead is offline
OK, so no good on the stroker idea. Did you have to re-sleeve the block to bore it out that much?
MY TOYS
95 SVX
98 Lincoln MarkVIII LSC, 5-speed swap
91 Marcury Cougar, 393" stroker, completely insane!
89 Mercury Cougar XR7, supercharged V6/5-speed, one of 2209. Engine currently dead, replacement in garage being rebuilt.
80 Pontiac Firebird formula, 350TPI swapped in, car needs to be finished.
Old 12-08-2008, 11:03 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Very nice job, first I've heard of this one. Any specifics on the cam profiles you're running? Also, any info on the ignition system? Looks quite nice.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 12-08-2008, 01:59 PM
RallyBob's Avatar
Specs are here in the original thread.
Uses the Autronic CDI box and individual MSD coils.
Bob Légère
EG33 Impreza tweaks
Old 12-08-2008, 02:11 PM
RS22b's Avatar
RS22b RS22b is offline
Send a message via AIM to RS22b
So wait a second here. Does that mean that EFI is tuning Autronic?
that would be awesome!
_billy
www.brokenmotorsports.com
9 subies, 1-914 and a Dakar!
But still looking for my project SVX
Old 12-08-2008, 02:25 PM
RallyBob's Avatar
_billy
Yes, they have tuned quite a few.
Bob Légère
EG33 Impreza tweaks
Old 12-08-2008, 02:40 PM
RS22b's Avatar
thats great!
We are not too far apart either. Still on the hinge as far as which system im going to get but being they can do the Autronics i assume they can also do Motec and Pectel?
thx.
_billy
Old 12-08-2008, 02:47 PM
RallyBob's Avatar
thats great!
thx.
_billy
I think Chris has worked on Motec, probably not Pectel. It's not as common in North America FWIW. I rate the Pectel along the lines of DTA Fast, Emerald, Luminition and Hestec, fairly common in Europe but not over here.
Bob Légère
EG33 Impreza tweaks
Old 12-08-2008, 02:50 PM
RallyBob's Avatar
My understanding is that the machinist did not sleeve the block. He cut up Jack's old damaged block and deemed the OEM cast-in sleeves thick enough for naturally aspirated use.
Bob Légère
EG33 Impreza tweaks
Old 12-09-2008, 11:11 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
wow awsome work !!!
Old 12-09-2008, 03:43 PM
intellibomb's Avatar
intellibomb intellibomb is offline
me gusta el INTAKE
*droooling*
very nice work.
my hat is off. next project: do this to an svx!
Old 09-27-2012, 12:35 PM
BackWoodsBob BackWoodsBob is offline
Good god. I've found them, finally.
