Old 03-17-2008, 02:40 PM
TN_fwdsvx's Avatar
TN_fwdsvx TN_fwdsvx is offline
SVX Owner
Tom is correct; SUS is for Sport Utility Sedan. It is a Legacy - with the Outback treatment. Including the limited-slip rear diff. Car is also raised (eight inches of ground clearance!), if you are going to take it on the track, you might want to lower it or replace suspension components with stock Legacy parts (which will lower it, right).
Btw, check my signature - The two non-SVX cars are SUSs.
Tom Millican
'92 SVX LS-L, Claret [Daughter's]
'94 SVX LE (FWD), Barcelona Red
'99 Outback SUS, 2.5L, Winestone (Burgundy/Gray) [Daughter Killed it]
'02 Outback SUS VDC, 3.0L, Green/Gray [Spouse's; Died at 500,000+]
'18 Legacy w/eyesight, Blue [Spouse's]
'94 Subaru Sambar KS-4, White [Farm UTV]
'94 Ford Ranger Extended Cab, Tomato Red
Old 03-17-2008, 04:16 PM
You are right on all accounts except they do not have LSD... I can promise you that
Old 03-17-2008, 07:22 PM
94SubieSVX's Avatar
OOC for a while
This is SICK!
.....So I'm driving it to Reading???
bLAh
Old 03-17-2008, 07:36 PM
PICTARS
tOM
Old 03-18-2008, 06:05 AM
shotgunslade's Avatar
Hey:
I recognize that snorkus. Either I wrapped the insulation around it myself, or the sincerest form of flattery has been offered in this intake tube. Either way, glad to have been able to make even a minimal contribution to this fine effort. This is a picture of it in its first incarnation, replaced by the fine Tomyx custom intake snorkus.
Old 03-18-2008, 07:13 AM
Yea Dan, due to the legacy airbox being located just slightly off of where the Stock SVX airbox is, it made a poor fit for the stock snorkus... So we hhad to use yours make it somewhat "adjustable"
TOm
Old 03-18-2008, 08:11 AM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
That's awesome! If nothing more than to see yet another crazy plan come to fruition.
So all this talk about it being fast... are you saying it's faster than the supercharged SVXes, 4.44's, and all the other goodies you got going on?
What makes this thing so fast? Is something done to the engine? It's N/A right?
It seems like every time the EG33 is dropped into another vehicle it is faster than the SVX, even back to the days of Smallcar installing them in Vanagons. Why?
Looking at the parking lot shots with the cars side by side, it's a crime if the SUS is faster than any of those SVXes. I know sleeper cars are cool, but it's still a crime.
BTW, is this going to remain in full SUS trim and be utilized offroad?
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 03-18-2008, 08:27 AM
Tom:
Like I said, it is a privilege to make a contribution, however small, to this worthy endeavor.
Dan
Old 03-18-2008, 08:50 AM
Originally Posted by TomsSVX View Post
Sport Utility Sedan keep up with the times man... BTW its a legacy
Subaru probably referred to this production project as Sport Utility Xperimental, but then the marketing people stepped in...
but if you crossed an SUS with an SVX, what else could you call it?
Just kidding! an awesome job. can't wait to see it at Reading.
Old 03-18-2008, 09:22 AM
I cannot be sure as I have only been able to drive it in a gravel parking lot
Yes I do plan on keeping in SUS trim and take it to the trails to do some rally driving My wagon has been subject to some offroading but the SUS seems so much more capable I cannot wait to get the reg. on it this weekend and take it to the streets I will take it on the trails this weekend during out meet, hopefully we can take a break from the shop and all head to the trails for some good fun
Old 03-18-2008, 10:47 AM
I'm looking forward to driving it as well. I will be doing the paperwork for it tomorrow hopefully.
Tom, we will not be jumping the SUS. Just FYI. Look at how your last attempt landed!
Old 03-18-2008, 11:53 AM
courtesy of Hocrest:
Old 03-18-2008, 02:06 PM
Gr8Dane's Avatar
Gr8Dane Gr8Dane is offline
Resident Filmmaker
Somebody obviously watched RoboCop recently hahahaha
[SIGPIC][/SIGPIC]
-'94 SVX LSi Laguna Blue--MFD. 11/93--"Neptune/Poseidon"--52k miles
"BMW is the pioneer of character lines?
Whatever. Take a look at my Subaru's windows
and tell me those lines don't have character.
Punk."
Old 03-18-2008, 04:52 PM
Powered by Tom.
Old 03-18-2008, 05:28 PM
don't make this a pic war Mike
