Old 12-14-2007, 12:46 PM
Originally Posted by Boxersix View Post
Again prices vary according to what's in a kit and I cannot just simply quote a price based on speculation on my part. It could come way in over/under what I quote and either way that's bad on my part. Same goes for just the brackets as prices are based by design, which I haven't exactly worked up yet.
To give you a rough idea, that kit pictured above I listed for $1490 exactly as you see it. My four corner PCCB kit for the Audi RS4/RS6 runs near $12K, but it has $11K in rotors/calipers/pads alone.
Give me some time to work out the details on this and I'll get back to you all
Ok cool. We definitely need specs.... let us know when you are ready
Old 12-14-2007, 07:10 PM
Psychosis5150's Avatar
Psychosis5150 Psychosis5150 is offline
Yugo aficionado
Wallet in hand, fingers crossed
92 Teal 181K
4:11 trans
Lightweight crank pulley
Redline Shockproof
Trans Cooler
Viper 550 HF Alarm/Remote Start
18" Enkei Evo5's
Old 12-15-2007, 07:46 AM
wawazat??'s Avatar
Yeah, I'm still around
watching and waiting
Down to none
Old 12-15-2007, 08:22 AM
The easiest thing for you/us to do would be to modify the wilwood BBK for an sti. The rotors have the right bolt circle (04+). The 6 piston calipers are just as much as anyone here will need. All I need is someone to make a new bracket for them, as I do not yet have the capabilities to do so. Take the wilwood bracket and reduce the height of the bracket by 1/2". When I say this, I mean, make the caliper 1/2" closer to the center of the hub and you are golden. I was going to be doing this in the future but if you can do it now, by all means
Old 12-15-2007, 08:26 AM
sicksubie's Avatar
05+ I think.... 04's still had the 5x100bcp
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 12-15-2007, 08:35 AM
yeah ur right. Sorry
tom
Old 12-15-2007, 12:15 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
All I need to do that is the dimensions of the 05+ bracket and I can make a CAD to CNC brackets if that's easier for you.
What's the part number for this Wilwood BBK kit you're referring to? I can probably get one of the brackets to get measurements from....
Old 12-15-2007, 03:03 PM
sicksubie's Avatar
This sounds great...... (carries hammer over to piggy bank)
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-17-2007, 01:13 PM
Boxersix's Avatar
Hey guys...what Wilwood BBK are you refering to for the 05+ STi.
their website only lists a kit part number 140-7005 which is listed for 99-04 year model STi's...whcih have the 5x100 bolt pattern not the 5x 144.5(4.5") bolt pattern. The bracket part number for the 7005 kit is 250-6991 but if it's not what I need then I'm just going to be running in circles here trying to get the correct measurements I need for you guys.
I'd like to be able to offer you guys a modified wilwood adapter to make these kits work if it's what you want, along with my monoblock brembo adapters.....
I need a kit part number, or the wilwood PDF file for the install of the 05+ kit as that lists the part number for the bracket i need to get.
Let me know....
Old 12-17-2007, 02:43 PM
the kits for all imprezzas are the same dimensionally. The only differences are the 5x100 bolts circle and the 5x114.5 bolt circle that we need. The brackets are the same just the rotor hats are different. So you could use any imprezza bracket to make yours from
Old 12-17-2007, 02:53 PM
I would say call wilwood about them. i cannot find a diff part # for the different kits
Old 12-17-2007, 03:29 PM
Boxersix's Avatar
I will call to double check that as I dislike machining parts based on a whim.
The 250-6991 bracket is a tad under $50 for a single unit so if it's the correct part it's cheap to get to pull dimensions from.
-Adam
Old 12-17-2007, 11:14 PM
It's Just Eric's Avatar
Missing in action
Just looking at some of your other posts and such gives me the feeling your going to be making some SERIOUS progress in the field of svx performance. I'lll keep an eye on this thread, and mabey start reconsidering my plans for this year's tax return
R.I.P Cool Signature.
Old 12-19-2007, 09:35 PM
wawazat??'s Avatar
Took some photos tonight of Brembo monoblock calipers (996 blacks) and StopTech calipers with a WRX Stoptech rotor and caliper adapter bracket. The spacing looks identical and it appears both will work with the same bracket enabling me to finaly put to use many $$ worth of brakes
I'll post pics tomorrow night.
Todd
Down to none
Old 12-19-2007, 09:58 PM
Boxersix's Avatar
Todd
Most Porsche radial mount spacing is 130mm center-to-center on the radial bolts. Not sure what the Stoptech is. If those two dimensions are the same and the radial-to-caliper center distance is the same they can probably be used
