Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
So are fusible links rated that way? You ask for one that is that size?
. Earl .... ... .... ><SVX(*> Subaru Ambassador [COLOR=”silver”]1992 Tri Color L[/COLOR] ~45K (06/91) #2430 1992 Dark Teal LS-L ~184K (05/91) #0739 1992 Claret LS-L ~196K (05/91) #0831 1992 Pearl LS-L ~103K (06/91) #1680 1992 Pearl LS-L ~151K (06/91) #2229 1992 Dark Teal LS ~150K (07/91) #3098 (parts car) 1992 White LS-L ~139K (08/92) #6913 1993 25th AE ~98K (02/93) #164 1993 25th AE ~58K (02/93) #176 1993 25th AE ~107K (02/93) #215 1993 25th AE ~162K (02/93) #223 1994 Laguna Blue Pearl LSi ~124K (1/94) #2408 1994 Laguna Blue Pearl LSi ~144K (10/93) #1484 1994 Laguna Blue Pearl LSi ~68K (10/93) #1525 1994 Barcelona Red LSi ~46K (02/94) #2624 1994 Pearl LSi ~41K (12/93) #1961 1995 Bordeaux Pearl LSi ~70K (02/95) #855 1996 Polo Green LSi ~95K (03/96) #872 1997 Bordeaux Pearl LSi ~55K (08/96) #097 2003 Brilliant Red LS1 Convertible ~29K (04/03) #8951 1999 Magnetic Red LS1 Coupe ~33K (04/99) #6420 My Email | Old Locker | New Locker | Picture of 15 of the 19 Last edited by ensteele; 12-31-2007 at 01:17 PM. |
A copper wire of 1.5 m.m. diameter should have a nominal fuse rating of say 65 amps, which would make sense in respect of the SVX circuitry. There must be someone here with spare parts experience, who can provide qualified advice.
Interesting...
Since I went to Autozone or Kragen...one of the two, and found a roll of the fusible link wire, and you cut to size. I've done that while I'm working on the SVX electrical issue, and when I'm finally done, I'll get an OEM one from work.
Easier and cheaper than blowing them time and time again.
'92 SVX LS-L Project Car for Open Road Racing |
I guess the only way to really know that you get the right one is to buy OEM.
The rating, as far as I can tell, is either diameter or square mm in a cross section... The searching I've done has vaguely hinted at both.
Disclaimer: The above post is on the internet. |
...and post up the company, and all the information.
okay, back from AutoZone...
and I was a bit mistaken. There are colors for different gauges of wire, but what they offer is fusible link wire in different gauges rather than the exact rating. I purchased the 18 ga. wiring as it looked like the closest to stock for my application.
I might be wrong, but I figured rather than the 16 ga. or higher, that this would blow early rather than late. The company that makes this is Dorman Products. search under "fusible link" and you'll find the wire in the last page.
I had estimated from published chart figures covering standard copper wire, that 15 AWG would be the nearest, but as I understand it this is not readily available. You were right to be conservative. The supplier must be using plain wire rather than a soft wire, which is understandable. This information should be recorded within the how too stuff as it has been hard to come by. ![]()
#28
Here is what I have so far.
A substitute for the OEM fusible link: fusible link wire in 18 gage Dormanproducts.com http://www.dormanproducts.com If any of this info needs to be corrected or added to it, please let me know. When it is ok, I will add it to the How-To Documents.
. Earl .... ... .... ><SVX(*> Subaru Ambassador [COLOR=”silver”]1992 Tri Color L[/COLOR] ~45K (06/91) #2430 1992 Dark Teal LS-L ~184K (05/91) #0739 1992 Claret LS-L ~196K (05/91) #0831 1992 Pearl LS-L ~103K (06/91) #1680 1992 Pearl LS-L ~151K (06/91) #2229 1992 Dark Teal LS ~150K (07/91) #3098 (parts car) 1992 White LS-L ~139K (08/92) #6913 1993 25th AE ~98K (02/93) #164 1993 25th AE ~58K (02/93) #176 1993 25th AE ~107K (02/93) #215 1993 25th AE ~162K (02/93) #223 1994 Laguna Blue Pearl LSi ~124K (1/94) #2408 1994 Laguna Blue Pearl LSi ~144K (10/93) #1484 1994 Laguna Blue Pearl LSi ~68K (10/93) #1525 1994 Barcelona Red LSi ~46K (02/94) #2624 1994 Pearl LSi ~41K (12/93) #1961 1995 Bordeaux Pearl LSi ~70K (02/95) #855 1996 Polo Green LSi ~95K (03/96) #872 1997 Bordeaux Pearl LSi ~55K (08/96) #097 2003 Brilliant Red LS1 Convertible ~29K (04/03) #8951 1999 Magnetic Red LS1 Coupe ~33K (04/99) #6420 My Email | Old Locker | New Locker | Picture of 15 of the 19 Last edited by ensteele; 12-31-2007 at 01:16 PM. |
#29
A substitute for the OEM Fusible link, OEM part number, 82301PA000 : Suitable 18 AWG (American Wire Gauge) wire for making up a replacement fusible link for the SVX can be purchased in special small lots from:- Dorman Products. http://www.dormanproducts.com Plain, enameled or tinned copper wire can be used. The cross section/diameter for the original fuse link is specified as 1.5 m.m. There will be alternative wire gauges close to this which will also prove suitable. Better to choose on the small side, for a slightly lower current rating thus providing a safety factor.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by ensteele; 12-31-2007 at 01:16 PM. Reason: "Enameled" & part No. added. |
#30
Thanks Trevor.
