Prev Previous Post   Next Post Next
Old 08-04-2006, 07:41 PM
Joshua R. Abel Joshua R. Abel is offline
Bosch or Walker oxygen sensors
Has anyone ever had any problems with the Bosch or Walker Oxygen sensors? My car has been running pretty poorly for a while. When I did the check engine light routine, the code came up 02 sensor. So I swapped them out for some Walker sensors. They lasted about a week or 2 before the problem re-occured. I swapped them out for the Bosch and it didn't change anything.
I gave up on trying to fix the problem on my own, so I took it to the dealer. The technician said the code is still coming up- bad 02 sensor. So, I should just buy the Subaru 02 sensors @ $1,000,000 a piece, I'm sure, and this should fix the problem.
Any advice from anyone would be highly appreciated. And yes I already swapped out the spark plugs. So that probably isn't the cause.
Thanks in advance.
