Old 07-05-2006, 10:47 AM
GreenMarine's Avatar
From POST-***** to LURKER
Originally Posted by Earthworm
When you adjust the tensioner are you tightening the locking nut on the tensioner pulley after adjusting?
locking nut?.... I'm not sure if we are talking about the same thing... do ya have a picture of this "locking nut"? I would post a picture of my belts and tensioner, but I don't have a camera anymore
Old 07-05-2006, 10:57 AM
The nut in the center of the tensioner pulley. To move the pulley and loosen the belt, you first need to loosen the nut in the center of the pulley about one turn, then loosen the long bolt that actually moves the pulley. After reinstalling the belt and using the long bolt to tighten the belt, you need to tighten the nut in the center of the pulley to "lock" it in place.
Old 07-05-2006, 11:01 AM
Here ya go Chris, this is the locking nut...you have to loosen it then adjust the belt, and once it's adjusted, you have to tighten it back up, to hold it in adjustment.
Old 07-05-2006, 11:48 AM
duplicate.
Old 07-05-2006, 11:49 AM
It's not a "lock nut" in the traditional sense.
Old 07-05-2006, 11:59 AM
That is correct...it is a "Locking Nut" not a "Lock Nut"
Old 07-07-2006, 01:43 PM
Hmmm .... Ummmmm, what would happen if, when someone was attempting to tighten the belt, they forgot all about the locking nut??? What would happen if you just turned the bold that moves the pully?? Think that would be the cause of me going through so many belts?
Old 07-07-2006, 01:59 PM
hhmmmmmm.....yep....if you're not tightening the locking nut after you set the tension, it will just work loose over time.....adjust it, then tighten the lock nut, and you'll probably be fine
It sounds like the locking nut is loose and the belts loosen off, slip and burn up.
Old 07-07-2006, 02:53 PM
So I'll do this when I get home and see if it fixes everything... Ya don't think that I may have damaged the locking nut by not loosening it first before tightening the tensioner?
Old 07-07-2006, 02:57 PM
I'd be more worried about the tensioner assembly. If the pulley is allowed to wobble there's a chance it may break the assembly the pulley mounts to.
Old 07-07-2006, 05:13 PM
alright... going downstairs to tackle this little issue right now.... Hopfully I'll go for a testdrive and make sure it is all sorted out after I finish... Will report back within a few hours
Old 07-07-2006, 07:17 PM
Well, I hope that this doesn't jinx me.... But I took the belt off and spun all of the pulleys (PS, Alt, and tensioner). The PS pulley rotated smoothly about 3 revolutions, then some resistance built up. I imagine that this is normal (pumping fluid). The alternator pully spun normally. The tensioner pully really was nice and smooth, and had no problem spinning...
I replaced the belt and tightened everything down (including the locking nut this time). Took it for a test drive and everything was nice and quiet... I am gonna give it atleast a week before I get too happy... Possibly if I get the $$$ I will go do the upcoming AutoX in Greenville, NC on the 23rd and use that as the main test
I sure hope that this worked though Would save me some money and time for sure
Old 02-26-2013, 01:31 AM
SVXalter's Avatar
SVXalter SVXalter is offline
Re: WTB : Powersteering Pump and Tensioner Pully
Resurrecting this thread from the dead. Does anyone know if a special type of nut is required for the "lock nut?" Mine has fallen off completely after not touching the belt for well over and after experiencing no squeaking.
Any other tips for replacing it would be greatly appreciated as well.
Thanks!
-Dan
1996 Polo Green SVX L - 85k
1992 Ebony SVX LS-L - 193k (parts)
