b8 refers to pin 8 of B67 (the middle one of the three connectors). It's a white wire. Diagram for reference: http://www.subaru-svx.net/photos/files/b3lha/33820.jpg
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
Ok thanks I will check it out as Mike hasnt even replied as to wether or not he shipped out the tcu (hopefully he did and he is just away from his comp)
1989 Subaru XT6 130k 1992 Subaru SVX 120k 1993 Ford Probe 30mpg 213k 1989 Subaru XT6 150k All good and running |
Harvey this is an interesting concept you have outlined and I had hoped for a reply to the above, as possible advantages of use to members are indicated. I always drive in third within city limts in order to prevent the transmission from hunting up and down in and out of drive. Using power mode would move up the shift points, as I see it, only at full full throttle. But there should be no hunting betewen low and second. There is reason for further investigation, in order to possibly utilise this feature as a means of protecting the transmission against overheating. Circuitry must exist involving the ATF temperature sensor and it may be possible to incorporate some form of overide switch. Others will be interested in this prospect and your reply will be appreciated, Trevor.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
PS: I haven't done full throttle on my yellow one after the second swap...trying to take it easy first. (only 300miles driven) I tested it the other night...I only quickly moved down my throttle about 1/3, the power mode could raise my shift point at 5000rpm of the second gear. ![]() Spinn360, as you said, your power mode will randomly activate. But could you activate your power mode when you want to?
-SSSVX 92 LS-L TEAL since Aug '01 92 LS-L YELLOW since Mar '05 |
I keep the power switch on all the time except during motorway cruising. I've found that it does not seem to effect the overall fuel economy and I enjoy the more responsive feel. I also use position 3 a lot and hopefully these measures taken together will extend the life of the transmission. There are so few of us with JDM cars that the idea is irrelevant to most people. I recently suggested that someone with a USDM SVX should try connecting a switch in the same way that the JDM one is connected and see if it works. Does power mode definitely stop the TC from locking? As Earthworm said, that could be a downside due to the extra heat generated. I can never really tell whether mine is locked or not, but the SVX is always very responsive, power mode or not. When I press the pedal, the acceleration is *instant*. On all other automatics I've driven, (mostly Mercedes, but also Jaguar, Vauxhall, Peugeot and a few others), when I press the pedal, the rev counter climbs and then a few seconds pass before the car starts to accelerate. Phil.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 04-15-2006 at 04:06 AM. |
Power mode.
I found this bit on it, from a while ago,
http://www.subaru-svx.net/forum/show...ght=power+mode In the Australian Manual, it says that the ATF temp sensor, "Detects ATF temperature. This signal is used for inhibition of Lock up, release of OD and detection of ATF temperature." So it looks like it unlocks the converter, and shifts it back to 3rd. A bit different to the End Wrench description. Harvey. ![]()
Harvey, please don't take offense, I'm poking fun at the manual, not you. ![]() Good info as usual! Dan |
If the signal unlocks the torque converter, surely this will result in the opposite of a reduction of heat within the trasmission. Shifting back to third will surely not offset possible heat generation by the converter, which several here have pointed out, could be a major culprit. We still do not have an answer as to what has been suggested.
![]() ![]() Harvey. ![]()
yeah, never thought it would kick it into power mode just keep the TC from lcoking up to get the fluid going. Maybe if the engine begins to overheat it will kick to power mode, rushing coolant and trans fluid through the radiator faster??
![]() Tom |
more info
I havent checked the wire yet. but I thought I would post on a new occurance. The speedometer is bouncing up and down as I drive it. sometimes with the rpms sometimes not. Does the tcu see this? could this have something to do with my problem. Also I was thinking about when I first got the car. The battery was barely grounded. I didnt know this until problems started to happen. The abs light blinked. the powersteering light blinked and I had and didnt have pwersteering. I found out shortly after that the ground wires were: 1 was connected to plastic, 1 was corroded at connection, 1 was nearly burnt(this was the one that was the only one connected) I think this might have fried my TCU but the only thing is that that all happened over a year ago, and as soon as I re-ground the batt the problems went away. So what do you think???
#28
#29
ok so no damage from the one little wire that was nearly burnt bieng the only ground.
But now the speedometer says I am going 60 on start up if I give it gas I can get it up to 160. Hey maybe I will take a picture so I can post how fast my SVX can go! And not even running properly!! ![]() Well maybe I will test that wire out if I get a chance after work. If the tcu still hasnt come that is. Does the speedometer get info from the tcu? because if I remember correctly theres wires on the front diff for the speedometer right?
1989 Subaru XT6 130k 1992 Subaru SVX 120k 1993 Ford Probe 30mpg 213k 1989 Subaru XT6 150k All good and running Last edited by spinn360; 04-18-2006 at 12:40 PM. |
#30
You can see the wiring in the diagram I posted earlier. The signal from speed sensor 2 goes to the TCU and the speedo.
It sounds like you might have a ground fault in the wiring for the TCU. The TPS wire shorting to ground causes the power mode to come on. The Speed sensor wire intermittantly shorting to ground due to engine vibration might produce pulses that the speedo would misinterpret as a speed signal. Trevor, or one of the other electronics experts may have a better theory.
