Old 01-28-2006, 05:20 PM
BigBlueSVX's Avatar
BigBlueSVX BigBlueSVX is offline
Donate to the mod fund
Send a message via AIM to BigBlueSVX
Advice needed ASAP: sticky tranny pan
so my transmission pan started leaking after I went to a shop to get the ATF changed. When a second shop looked into it while replacing the front diff, they found the whole pan sealed off with silicone, so they said it needed a new pan and just put more silicone on. And it still kept leaking. So here is my dilemna: I have a new pan and gasket to put in to hopefully fix the problem and all the bolts are out, but the pan won't budge. It's sealed to the case, and I can't get enough leverage to pull it off, as the car is only on ramps. Do any of you have any ideas how to pull off the pan or loosen the seal? Thanks.
1994 blue FWD Subaru SVX L with 86k and the original tranny *SOLD*
My Cardomain page
Now part of the DSM crowd: 1990 Mitsubishi Eclipse GSX
Old 01-28-2006, 05:26 PM
Get the smallest hammer you can find, beat the pan edges GENTLY all along, it will eventually come off.
BE SURE YOU DIDN'T FORGET ANY BOLTS IN THERE
Old 01-28-2006, 05:48 PM
michael's Avatar
michael michael is offline
What Potholes ???
Floss it off with a piece of wire.
Wanted: Steering Wheel
Old 01-28-2006, 06:07 PM
I would try to floss it off or use some kind of thin blade. I don't think a hammer will do anything to a pan sealed with silicone. Maybe it will.
Old 01-28-2006, 07:16 PM
BigBlueSVX's Avatar
thanks for the help, the flossing idea sounds good, I'll try that next. So far I've done everything from beating it with a mallet to pulling on it as hard as I can, but I just can't get enough leverage. Even tried sticking a hot knife in between the pan and the case, and that didn't do much . Keep the ideas coming!
My Cardomain page
Old 01-28-2006, 09:47 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
c4~~
no, not that...i'm sure the pan would come off and more than that...
have you tried exacto knives....though i would imagine the blades are either not sharp enough or....would snap....
small crow bar?
use a sh!t load of flat head screw drivers and stick them in numerous points and try pulling at intervals and/or combinations?
