Old 08-14-2005, 10:40 AM
n00b on demand's Avatar
the car looks good except for those wimpy headlights......car loks retarted with those lights on there.
Old 08-14-2005, 11:15 AM
Tim-H
Anyone else notice the cupholders are missing? Man those suby designers really dont want anyone drinking in the car do they?
Old 08-14-2005, 11:41 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Woo Hoo! Now subaru will have 2 flops sitting on their lots. Hopefully they'll get back to making solid dependable awd cars and get away from this speed ricer concept they've adopted lately. Kill the stinking Impreza that consumer reports said way back when the platform was introducted in 93 wasn't all that impresive even though it was leaps ahead of the loyale.
Old 08-14-2005, 12:53 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
Originally Posted by NikFu S.
I've got $100 on 320hp and 315tq.
While the official figures haven't been released, this article on subdriven mentions that the '06 STI will have 311ft-lbs of torque - there's no mention of an increase in hp.
http://www.subdriven.com/news/publis...icle_378.shtml
Personally, I won't be surprised if the 'official' hp rating remains at 300...even though the actual rating will probably be in the 320-325 range. Subaru seems to be starting a trend of under-rating their engine output of late (e.g. '04-'05 Forester XT).
-Chike
2006 Steel Gray WRX TR (sold)
Old 08-14-2005, 01:06 PM
-Chike
Because then people will be like, " OMG what an engine!"
Old 08-14-2005, 01:13 PM
Chiketkd's Avatar
The '06 Impreza actually has two cup-holders - but they're in an akward location beside the parking brake:
-Chike
P.S. The more and more I look at the '06 Imprezas, the more I like Subaru's new corporate face.
Old 08-14-2005, 01:25 PM
Chiketkd's Avatar
Originally Posted by Phast SVX
you know i think the WRX looks better then the STi..
That's my feeling as well Phil.
I'll definitely test drive an '06 WRX this Fall. My wife likes them and it'll fall within the 26-27K price range she's given me. I'll also test drive an '05 Forester XT (still several new ones on dealer lots - hate the '06 redesign), an '05 Legacy 2.5GT and maybe even a pre-owned '04/'05 STI.
However, I believe in supporting Subaru, so I'm 99% sure my next car will be purchased brand new.
-Chike
Old 08-14-2005, 02:18 PM
new from Landshark Studios (a division of Jackass Industries)......new body kits for yu0r ugly '06 Impreza!
as i was messing around with these, i realized the headlights are almost as awkward as the grille. the foglights and lower rad opening don't seem to flow with anything, either. its a really sad design. Subaru is really dropping the ball.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 08-14-2005, 02:45 PM
Chiketkd's Avatar
'06 WRX Specs...
2006 SUBARU IMPREZA® WRX®
WRX TR Sedan WRX Sedan WRX Sport Wagon
WRX Limited Sedan WRX Limited Sport Wagon
Specifications
Body Styles 5-passenger sedan 5-passenger wagon (except WRX TR)
Engine Horizontally opposed (“boxer”), turbocharged/intercooled
Block Specially reinforced die-cast aluminum with integral cast iron cylinder liners,
five main bearings, semi-closed deck cylinder block design
Cylinders 4
Displacement 2,457 cc (150 cu. in.)
Bore x Stroke 99.5 x 79 mm (3.92 x 3.11 in.)
Heads/Valvetrain Aluminum alloy cylinder heads with double overhead belt-driven camshafts (DOHC),
four valves per cylinder, Subaru AVCS (Active Valve Control System) variable valve
timing and sodium-filled exhaust valves
Compression ratio 8.4:1
Max. boost pressure 13.5 psi
Horsepower 230 @ 5,600 rpm
Torque 235 @ 3,600 rpm
Fuel/Induction Sequential multi-port fuel injection (MFI) with multi-spray injectors and Tumble
Generator Valves, Electronic Throttle Control (ETC) system, turbocharger, intercooler
Ignition Direct with iridium-tipped sparkplugs
Firing order 1-3-2-4
Emission control system Low Emission Vehicle (LEV) standard, 50-state certified
CA LEV 1 / Fed Bin 10
Fuel requirement 91 octane minimum
Alternator rating 12V, 110 Amps
Drivetrain Symmetrical All-Wheel Drive
Transmission types Standard: 5-speed manual transmission Optional: 4-speed electronic automatic with
lockup torque converter (WRX Limited models only)
Man. trans. All Wheel Drive
Viscous-coupling locking center differential
Auto trans. All Wheel Drive
Variable Torque Distribution (VTD) using planetary center differential and
electronically managed continuously variable transfer clutch
Gear ratios 5-speed manual 4-speed electronic automatic
1 3.545 2.785
2 1.947 1.545
3 1.366 1.000
4 0.972 0.694
5 0.738 --
R 3.333 2.272
Final drive 3.70 with viscous limited-slip rear differential
3.90 with viscous limited-slip rear differential
Chassis Unitized body construction with Ring-Frame Reinforced structure, hydroformed front
subframe and tailored blank-welded side sills and B-pillars
Suspension 4-wheel independent, sport-tuned (sedans with wider front track)
Front MacPherson-type struts with steel lower L-arms, aluminum transverse links, liquid
filled L-arm rear bushings, coil springs, stabilizer bar and negative-scrub geometry
Rear MacPherson-type struts with coil springs, trailing arms, twin aluminum parallel links
and stabilizer bar and negative-scrub geometry
Brakes Power assisted 4-wheel disc with 4-channel, 4-sensor anti-lock brake system (ABS)
and Electronic Brake-Force Distribution (EBD)
2006 Subaru Impreza WRX Specifications / 2
Front disc size 11.5 in. x 0.94 in., ventilated with 4-piston fixed-position calipers
Rear disc size 11.3 in. x 0.71 in., ventilated with 2-piston fixed-position calipers
Steering Rack-and-pinion with engine-speed controlled variable power assist and load-sensing
valve
Ratio 15.0:1
Turns, lock-to-lock 2.7
Turning circle 35.4 ft. curb to curb
Wheels 17 x 7.0JJ aluminum alloy
Tires 215/45 R17 91W Bridgestone RE92 all-season
Exterior Dimensions
Coefficient of drag (Cd) Sedan: 0.33 Sport Wagon: 0.37
Wheelbase 99.4 in.
Length 175.8 in.
Height Sedans: 56.7 in. Sport Wagons: 57.7 (58.5 inc. roof rails)
Width Sedans: 68.5 in. Sport Wagons: 66.7
Track (f/r) Sedans: 58.5 in. / 58.3 in. Sport Wagons: 57.7 / 57.3
Ground clearance 6.1 in.
Curb weight (lbs.) 5-speed manual 4-speed automatic
WRX TR Sedan NA NA
WRX Sedan 3,192 NA
WRX Sport Wagon 3,252 NA
WRX Limited Sedan 3,239 3,296
WRX Limited Sport Wagon 3,294 3,347
Interior Dimensions
Headroom (f/r) Sedans (ex. Limited) : 38.6 in./36.7 in. Limited Sedan (moonroof): 36.3 in./36.6 in.
Sport Wagon: 39.7 in./37.3 in. Limited Sport Wagon (moonroof):
36.3/in./36.6 in.
Legroom (f/r) Sedan: 42.9 in./33.0 in. Sport Wagon: 42.9 in./33.7 in.
Hip room (f/r) Sedan: 53.3 in./51.9 in. Sport Wagon: 53.3 in./51.7 in.
Shoulder room (f/r) 52.7 in./52.9 in.
Trunk volume, sedan 11.0 cu. ft.
Cargo volume, Sport Wagon
EPA rear seat up: 18.0 cu. ft. SAE rear seat down: Pending
EPA interior volume Sedan – 87.6 cu. ft. Sport Wagon – 90.4 cu. ft.
Capacities
Fuel 15.9 gal.
Engine oil capacity 5.0 qt. w/ filter
Coolant capacity 8.1 qt. (8.0 qt. with automatic)
Towing capacity 2,000 lbs. (Class 1), 200-lb. tongue weight
Fuel Efficiency 5-speed manual 4-speed automatic
EPA city mpg 20 21
EPA highway mpg 26 26
http://www.subdriven.com/news/publis...icle_390.shtml
-Chike
Old 08-14-2005, 02:55 PM
Hotness.
Old 08-14-2005, 03:33 PM
drivemusicnow's Avatar
Poor College Racer
I don't mind the front end as much as I thought I was going to. And i have to say, I think it definitely gives the company a "common face" while a lot may not agree with it, at least you'll be able to instantly recognize a subaru on the road. Think about how you can always tell BMW's, Pontiacs, Mercedes, and Porsches immediately just by the nose. I think it might help subaru more than we realize.
Plus, i GUARANTEE the 2.5t to be going faster than the 4g63 by the end of 06 Displacement helps.... especially when putting down streetable power.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 08-14-2005, 03:45 PM
Tim-H
You know I just noticed the radio antenna, or lack of one. I would Absolutely love to get my radio antenna shaved off. I hate how it looks and how it wobbles going down the freeway. But the reception absolutely sucks when its not extended.
The more I look at the front end, the more it looks like a legacy rather than an impreza.
I just looked up what the TR was, cause i hadn't heard about it. Apparently its "Tuner Ready" and sells cheaper. Sounds like every teenager and their little brother will be buying those up.
All I can say is I can't wait for the 2008 Revision, hopefully they wont let quite so many subaru enthusiasts down next time.
Old 08-14-2005, 05:04 PM
benebob's Avatar
-Chike
Chike, put her in a Baja Turbo if you must go with a new subie. Personally, I'd find a nice 95ish Impreza though. I wouldn't support a company that can't seem to make a quality vehicle now.
Old 08-14-2005, 05:29 PM
Chiketkd's Avatar
Ben,
While the Baja turbo is extremely fast, b/c it's built on the legacy platform (unlike the Forester XT that's built on the impreza) it weighs a stout 3,400-3,500lbs. I really want a light-weight car that I can use both at the dragstrip and autox events.
The Legacy 2.5GT and WRX are therefore my front runners.
-Chike
Old 08-14-2005, 05:47 PM
didn't you know that WRX's are for t00ls?
