Old 06-15-2005, 08:08 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Originally Posted by Hohopirates
Well I filled it with the car running and no bubbles. I just don't get it, I mean this thing was leaking bad and now nothing? I'm scared my car is going to strand me in the desert.
Steve
Steve,
Okay, it looks like the block is okay (no bubbles)...by any chance is the overflow reservoir full? I agree with the other posts - start checking all of the hoses to see if there isn't a loose hose clamp or pin hole hiding out.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-18-2005, 07:55 AM
down under down under is offline
not as difficult as it sounds
try putting a joiner between the 2 heater hoses at the fire wall Subarus are prone to leaking heater cores which expel through drain pipe below firewall so you dont see or smell it. Mind you i discovered this by destroying an engine and a heater core. Then i found the mechanic who knew the answer [BUGGA]
