Old 06-01-2005, 07:07 PM
Subafreak's Avatar
Superbeast
Oh boy, Sounds like I do need to get there early. I really don't think it could be that bad, It not like you were running NOS or anything
A headgasket is possible but we all know what burning antifreeze smells like
So you say it's running fine now? I don't know man
I hope we can figure it out in time!
Old 06-01-2005, 10:35 PM
Well my origonal thoughts on it seem to be truer than any other. I think the pass front injector got clogged up. Thus leaning that cylinder out causing detonation and burning a hole though my piston. this is now oil is leaking out into this cylinder which I am burning and leaking out of my exhaust. Not too happy with it but I will be picking up a Junk yard motor soon enough. The motor in the car will be put on the bench and preped for a stage 3 with the 2.2t pistons(gradual build). This will be equipt with the stage 3 S/C once a 6mt comes by my way. I know it sounds a little overzelious but it seems to be the best plan of action. Good thing I didn't buy the konis or else id be pretty screwed. I am not happy with this situation at all but I do believe it is the most proper plan of action for me to take.
Tom(not racing anytime soon member)
Old 06-02-2005, 05:26 AM
LarryIII LarryIII is offline
Tom,
I am really sorry about your misfortune with your engine.
I'll see you tonight. Maybe I can cheer you up.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 06-02-2005, 09:28 AM
KCROGUEDOG
check all the plugs. i had a coil go bad and i replaced it and the plug. ran good for a day. little did i know my car still ran like piss. so i checked the other plugs and all 6 were shot even the one i just installed. so replaced all 6 and volia alls good. one bad plug can cause all to go bad trying to compinsate for each other. especially with a coil pack shot.
Old 06-02-2005, 09:30 AM
Will a new plug help the big arse hole in my piston?? I never knew they could do that Just kiddin thanks for the advice anyway man
Old 06-02-2005, 09:35 AM
mbtoloczko's Avatar
sans SVX
Have you done a compression check on the cylinder with the fouled plug?
Mychailo
Visit my locker
Old 06-02-2005, 09:37 AM
I planned on doing it when Jesse got here today but now that you have motivated me to get off my ass I will do it now
Old 06-02-2005, 01:01 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
sounds like a fried ring leaking oil into your cylinder. also knock could have burnt a hole into your piston. i would check all your injectors to make sure one isnt leaking.
edit, i should read before i post.
Old 06-02-2005, 02:12 PM
KCROGUEDOG
join the club on reading before posting.
Old 06-02-2005, 02:13 PM
KCROGUEDOG
or posting before reading. error i correct myself.
Old 06-02-2005, 09:25 PM
Well Jesse cam and took a glance at it today. He is thinking rings also. I can only imagine that one broke but I cannot tell until I take it apart. the #1 cylinder is the one giving me the problems. It has 150psi worth of compression checked the #3 and it has 210 worth of compression. I would say that there is definately a problem there. Anyway I am in the market for a junkyard motor for now and I will rebuild the motor in it as a gradual project.
Old 06-03-2005, 07:14 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Tom float an email to Rufus, I know he had a good motor a few months back he was willing to part with. Other person to check with would be Nubs but I'm not sure if he pops in much during his busy season. He's friends with a JY owner between Lancaster and Lebanon who has a 95.
Old 06-03-2005, 08:45 AM
Thanks for the info Ben I might get a hold of them.
TOm
Old 06-03-2005, 11:22 AM
I have an update for anyone who cares. Found quite a few SVX motors around here. I found 3 that I am actually interested in
1. Manheim PA 104k 30 day war. for $500
2. Brooklyn NY 90k 90 day war. for $600
3. Brooklyn NY 88k 90 day war. for $500
All of the engines have been run and are claimed to be in good condition. I may be making a trip up to NY for engine #3 next week. I need to crunch some #'s and see what I wanna do.
TOm
Old 06-03-2005, 11:58 AM
benebob's Avatar
TOm
DON'T CALL THE PLACE IN MANHEIM!!! TELL ME WHAT IT IS FIRST. I used to work at MAA, still have some definate connections there. I probably can get it cheaper for ya. Is it J&D? If so that's the place that Nubs knows the owner of.
