Old 05-22-2012, 08:08 AM
Re: Lock-up clutch.
Originally Posted by dromano View Post
Huck, I recently (manually changed a/t fluid, about 5 quarts out & added 6 qts till atf showed on the dip stick. In the following week the engine died at quick stops, never done that before in 13 years
I was baffled as to why it died. I finally added 2 more quarts of atf & no dead engine when stopping fast since go figure, what do you think?
Sounds like maybe a TPS or IAC issue on yours, as yours isn't dieing when you put it in gear, but when you go to stop..... low fluid should not make the engine die, but will make the clutches slip, which is not good on the tranny for sure.
I'm definitely not the best 4EAT guy on here, so maybe someone else will chime in on it.
Old 05-22-2012, 08:18 AM
dromano's Avatar
dromano dromano is offline
Re: Lock-up clutch.
Thanks Huck, adding more fluid made the die issue go away, I have not experienced any clutch slippage, weird shifts or other tranny issues & as far as I know, per SOA, the tranny is the original never been rebuilt, I have been running Royal Purple syn since 1999
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 05-22-2012, 12:19 PM
Tapani Tapani is offline
Re: Stalls when shifting into gears.
Mine almost stalled today in stop and go traffic - I had to lift the throttle just after depressing it.... The tranny temp light flickered when the engine almost died.... lack of line pressure?
Engine revs dipped down to maybe 200 rpm - as close to a stall you can get....
Tapani
Old 05-22-2012, 10:53 PM
dromano's Avatar
Tapani
Tapani, I hope I'm wrong, sounds like you have tranny solenoid issues. Have a reputable tranny shop look at it. If you don't have one, do some research for a good shop in your area, a"good" shop will save you a bundle of gold
Old 05-23-2012, 01:55 AM
I hope so too
The stalling is engine management related in mine.
Interestingly enough, though, the ATF temp light flickers every time the engine tries to stall.
Tapani
Old 05-23-2012, 03:30 AM
I hope so too
Tapani
Shure it is not the oil pressure light.?
Old 05-23-2012, 10:58 AM
Yes Sir, quite sure. Interesting, isn't it?
If flickers everytime the engine tries to stall. The oil pressure light is the small "oil can" feature in lower part. This one is right next to the FWD light where the SVX shaped thing is on the left, higher up in the cluster and it says "AT OIL TEMP" .
Funny, eh? Maybe it is a "late JDM" thing .
Tapani
Old 05-23-2012, 05:14 PM
Tapani
Strange! There is no physical or psychological connection between the ATF temp light and the engine
This may be an electrical problem, that is causing the light, and the engine to respond together, but,,,,,,no idea.
Old 05-24-2012, 08:33 AM
Well, the light is on if the ignition is on and the engine is not running - TCU tells it to light up !
So, the TCU might think the engine is not running if the erev is below a defined value. On the other hand the TCU does throw a code if the erev dignal is missing..... this does not happen if it doesn't really stall....
Tapani
