Old 11-13-2004, 11:19 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Congrats on the purchase snik!!!
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-14-2004, 04:20 AM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
yeah no mater how bad condition a svx is in id buy it anyway. they will run forever if you fix them up. but i would definately completly replace your tranny. personally i would replace the tranny and rear diff with one from a 97 outback it has a higher final drive(4.44) witch improves acceloration greatly but lowers your mechanical max speed to 156 i think. do a search for 4.44 a few owners on this thread have done 4.11/4.44 conversion and like them alot.
someone post the link to dayle's svx store its 6 am and i can remember it.
that store has some great parts for the car at verry good prices. their rotors are good to and he has a built tranny that he swears by. and check out ecutune.com their stage one kit is the best thing you can do for the car. it improves low end tork and lets you run 87 octain instead of 93.
Old 11-14-2004, 10:33 AM
snik
thanks
did a lot of search on archives
looks like i will need a tranny and rear diff from a 96-97 Legacy Outback to get 4.44 gears.. also did a search for 4.44, and I am already looking forward to the extra toqrue
didnt come across any installation faq's,...am I to assume this is plug & play? it just bolts up, all electrical plugs fit, no machining/trimming required, etc?
I am gonna call the used parts places, .. I have 2 choices:
JDM parts
USDM parts
does it matter which shop i should call?
thanks again
Old 11-14-2004, 12:41 PM
Chiketkd's Avatar
Snik,
Check out the locker for SVX-FF. He has a write-up on his conversion to 4.11 gears. My locker has some pics of the process as I went with 4.11 gears as well.
The only member who has 4.44 gears up and running in his and his son's SVXs is SVXfiles. He also helped me a great deal in doing my swap.
Good luck!
-Chike
Old 11-15-2004, 09:26 AM
snik
ok, got a 97 automatic from a legacy outback (2.5L) + rear end for the same car for $1400 cdn ($1160 usd), car has 87k miles on it.
it has 4.44 gears so i guess that will fix my current tranny issues + gives me 4.44 gears
is that a good price?
as soon as swap begins I will take pics daily... check this post often (swap will most likely begin next week)
Old 11-15-2004, 11:26 AM
that was fast. this man i serious.
Old 11-16-2004, 05:44 PM
Any info on that engine? Is it siezed?
Old 11-16-2004, 06:09 PM
snik
engine is ok.
charged it, started it and it ran fine... i am gonna read the tranny error codes, and then drain the tranny fluid and remove the pan to see if there is any shavings there... & if oil is black.
if i find nasty surprises in there, i will swap w/ the legacy tranny and rear end
if oil is clean and all is well.. then mostl likely it will be a solenoid issue... can i buy the solenoid pack from the dealer? will the tranny need to come apart to access these solenoids?
i am hoping its just a solenoid issue, and that oil is clean w/ no shavings there...in which case i will install an auxilliary oil cooler and oil filter and change the solenoids and i am all set.
i have taken thu and fri off, so i will tear it apar on those 2 days and post results
in the mentime... talk to me about solenoids... i know how to pull the codes.. just wondering how much they are... are they back ordered... are they rebuildable... how do i access them...
thanks
Old 11-16-2004, 07:21 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
If the 4.44 rear is not a LSD then you will need to swap the ring and pinion out. The SVX rear drive axels will only fit a LSD rear.
Good luck and welcome to the site future 4.?? brother.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 11-16-2004, 08:05 PM
snik
Steve
how will i know if it has limited slip or not?
Old 11-16-2004, 09:02 PM
SVX-FF's Avatar
LSD diffs... the quick version
First you have to keep the final gear ratios the same. I.E. 4.44 in front, 4.44 in rear. DO NOT MIX MATCH If the 4.44 rear looks the same as your SVX rear then stick your fingure in the axle shaft hole. to feel if it is open all the way through. If so then it should be a LSD rear diff. I am about 95% sure of this.
If there is a large pin that obstucts the axle shaft hole the you will need to switch the ring and pinion onto the svx LSD. I used the svx rear carrige and just swapped the ring and pinion over. The LSD diff has notches cut into the housing. Carrier with nubs Carrier without nubs
LSD SVX dif on left / nonLSD on right
Side shot of LSD diff that will work with SVX
Additional Pics from svxfiles locker
Feel free to ask any questions you want, none will be stupid ones.
Steve 4.11 tranny swap writeup
Special thanks to Tom (svxfiles) for his photos that I used without asking.
Are you in?
My Old Locker
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 11-16-2004, 09:10 PM
snik
thank you again,.. ok, based on your description, I know how to identify lsd vs non-lsd now.. looking forward to sticking my finger in the rear end to see if its obstructed or not
this is my understanding of this whole thing...please correct me if I am wrong
a) if the legacy outback rear diff doesnt have LSD, then I use the 4.44 ring and pinion (from the legacy) and put it in the svx diff because the svx drive shafts will not fit a legacy diff that does not have LSD (I guess because the non-LSD legacy diff will have smaller holes & shafts wont fit)
b) if the legacy rear diff has LSD then i dont need to swap anything, i can just take the svx diff out and install the complete LSD equipped legacy rear end.
key point to remember is to grab the tranny & diff from the same car to ensure they match
am I missing anything?
thanks
Old 11-16-2004, 09:15 PM
SVX-FF's Avatar
BINGO You got it!!!
That is correct.
Steve
Are you in?
My Old Locker
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 11-16-2004, 09:27 PM
snik
yayyy... thanks
so I guess, I will be losing my lsd rear after the 4.44 upgrade...
if i happen to get a 4.44 non-lsd rear, I will have to swap the guts over to the inside of svx diff hosuing... & therefore losing my lsd along the way... oh well!
i also noticed in the picture gallery, the nubs were being grinded off... in your post you said the lsd rear has nubs... so i assume I will need to grind off the nubs on my svx diff when fitting a non-lsd pinion gear due to clearance issues
I am getting this... thank you again...
swapping the speedo sensor, installing an inline oil cooler and oil filter, doing the rear end thingie we discussed above and I am set
will post pics and results thu. night
Old 11-16-2004, 10:02 PM
SVX-FF's Avatar
You have to keep the LSD rear because of the SVX rear axles. Here is what I did for mine.
ring & pinion swap
Good luck
Steve
Are you in?
My Old Locker
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
