Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 09-26-2005, 05:55 PM
mbtoloczko's Avatar
sans SVX
Originally Posted by awdsvxh6
ok i'll say it again, it is not a EG33 block period. look at the pics. look at the pics and u will see that it doesn't have the EG33 stamp on the block he told me that they got the block from AM racing or something like that. so dont open your mouth and tell me to go and look at something else when i know what i am talking about.
Those markings are present on the EG33 case. The timing belt covers are a identical in appearance to the timing belt covers for an EG33. I don't see what else it could be.
Mychailo
Visit my locker
Old 09-26-2005, 05:56 PM
immortal_suby's Avatar
Thread Killah
Ok so it's a phantom one-off block that looks exactly like an EG33 but has something else stamped into it.
Locker Link
2015 BRZ Limited 6MT
Old 09-26-2005, 06:04 PM
Tofu
That's an EG33. I can take pictures of one that doesn't have any manifolds or other crap obscuring the top of the block at work tomorrow if anyone needs any convincing.
Besides, it's simple process of elimination. It's defenitely not an ER27. It's defenitely not an EZ30. It's possible they cast an entire new block with Subaru factory markings but not bloody likely. It isn't a mystery phantom Subaru R&D engine. That means it's an EG33. Done and out.
Old 09-26-2005, 06:16 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Agreed. It's definitely not the EZ30 as that engine uses a timing chain which is encased in a metal cover.
In the pic, you can clearly see the timing cover is black plastic.
-Chike
P.S. Here's another pic of the EZ30:
2006 Steel Gray WRX TR (sold)
Old 09-26-2005, 06:34 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
i have the same markings on my block. right behind the power steering pump. im preaty sure i have a eg33.
Old 09-26-2005, 06:48 PM
alltrac alltrac is offline
How easy we all forget. It's an eg33 that they claimed has been stroked out to 3.5L the max they could go. It has been posted before over here.
linky
Victor
Old 09-26-2005, 06:58 PM
cdigerlando cdigerlando is offline
Eg33
Guess you don't know what you're talking about
I'm sure the block has been heavily modified. I'm trying to find out what they are doing, and if they will make the mods commercially available in a watered down form for those of us who just want a measly 500HP
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 09-26-2005, 07:10 PM
mbtoloczko's Avatar
sans SVX
Wow. That's an ugly motor.
Mychailo
Visit my locker
Old 09-26-2005, 07:20 PM
Thread Killah
Probably the ugliest motor I have ever seen. Even a 5 hp briggs and stratton looks good next to it. Must be that big timing chain cover - do they have enough bolts holding that thing on?
Locker Link
Old 09-26-2005, 08:20 PM
is the ez30 the one from the xt6?
Old 09-26-2005, 08:45 PM
Chiketkd's Avatar
Nope...it's used in the Tribeca, Outback wagon and sedan. The XT6 had a 2.7L engine.
-Chike
Old 09-26-2005, 08:50 PM
Chiketkd's Avatar
They must really want to keep all dust & moisture away from that chain! Really is nasty to look at...
-Chike
Old 09-26-2005, 10:49 PM
thats not where the eg33 stamp is
mine does NOT say eg33. and as chicke will vouch i have an svx with an eg 33 in it.
Old 09-27-2005, 01:19 AM
how did they do it to 3.5L ? larger diameter pistons? or what?
Old 09-27-2005, 09:06 AM
A little advice to AWDSVXH6
You know, you started this, not me. Perhaps next time you will present your opinions with a bit more respect of the people that are on this website, most of whom are old enough to be your father, and who have extensive experience with these engines. Many of these people freely offer their assistance to others with no pay, and ask in return just a little courtousy. If you are unable to behave appropriately no one is going to take the time to assist you when you are in need.
You were wrong and rude about it and I slammed you back. Get over it.
Chuck D.
