Old 09-27-2016, 06:42 AM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Re: Alternator question
The alternator is still mounted below the crank pulley. It's too hot in Texas to go without air conditioning. I don't really like how it's mounted though so when I finally get it running right, I am going to look into what it would take to get a better mount created for it.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 09-27-2016, 12:09 PM
bishop bishop is offline
I see I see, I've never seen it setup like that, I assumed the a/c was deleted and the alternator flipped over to where the a/c would be.
Old 09-27-2016, 01:34 PM
halistan's Avatar
Grand Poo-Bah
Yeah, i like that he was able to keep the AC intact because you're right, most people take it out but it's just not feasible here. What I don't like about the alternator is that while it is very secure with the bracket, the adjustment side could be done a little better.
See, one side has the long bolt that holds it on and it is very strong so i'm not worried about it falling off but on the other side (the left side of the pic above) can you see a single bolt hanging down? That is the adjuster. There is square block on the back that has a hole in it that you put a bolt through and screw into the alternator. The lower you screw that block down the more tension it puts on the alternator and its not exactly the best.
I'll look into seeing if that can be re-fabricated to be more user friendly.
