#271
Re: SVX Engine cooling "Again & Again"
Tony,
I am not trying to demoralize you or the guys but I received a reply from that pro company. After I sent them detailed pics of the pump, they said they cannot do much for it, and more blades will lead to cavitation. He claimed that an electric pump with a controller is the best way to go.
#272
I understand Danny it not an issue to me. As it is I seem to be able to put peoples noses out of joint because I haven't done what they suggested "Yet" but I am one man that has a company to run at the same time as trying to fix this issue.
I was a beliver that we should push on with the existing pump but am tending to say the only way forward is to throw it and go electric such as Matt & Rally Bob suggests. We need to give the drilling a try but if the pump flow drops to low we will be no better. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#273
Good luck Tony, keep us posted
#274
I have detailed this possible way of dealing with the problem in every conceivable way. Exactly why this particular aspect is still not properly understood, is beyond comprehension.
#275
Trevor for god shake calm down, fixing caviation of the pump "ONLY" won't make the problems go away. It may turn out to be the biggest problem but it won't stop the left head overheating. When have to build the top pipe as Tom and then Havey has suggest the tee. As I have said its a package deal as it has to be a team effort to get this thing fixed, what happens if we stop caviation but indoing so kill the flow we will be no better off.
Tony
#276
its not the pump... Electric pumps have been tried and it is not the solution. Why would a modified stock pump be the solution?
Tom |
#277
Tom were is your thinking at? Were do you think we need to head next?
Tony
#278
I am confident a proper exit manifold will do the trick. Gotta give me some time before I can test it though
Tom |
#279
Giday all, ( Casey and Ducati Stoned them again.)
Well back to the question. I have read all this thread and the two other threads on the same subject, before this. I must say we are at a standstill, till some of the suggestions have been tested to see where we stand on the progress. The way you set up the fan to test the airflow was amazing, but then I read this, Quote:
I would go as far as to say that for road racing the extra cover that runs back under the gearbox should be fitted to enhance this action. The question of needing more water flow, to cool a performance engine, is a myth. The engine is air cooled at the radiator, the water is just the transporter. If more heat is to be removed, it has to be done at the radiator, not by pumping water through the engine at a faster rate, water does not change temperature any faster. Pump cavitation is a fact of engineering, it will happen with a standard engine. If the thermostat is partly closed it will restrict the inlet to the pump, and, at speed, it will cavate. If the impeller speed is high it will pull the molecules of water apart to form bubbles of void. These are bubbles of a very low pressure, so the water around the bubble will instantly boil due to the pressure drop. It is not hard to tell if this is the problem as when these voids explode into boiling, they will create small pock marks around the aluminum casing, very much like detonation marks around the edges of a piston. Having said that, I don't think the cavitation will stop the pump from pumping, in our case. Any modifications that you do the the impeller will reduce it's effectiveness at normal speeds. It is a trade off. So I can't add any more than I did in page #5, post #72. http://www.subaru-svx.net/forum/show...7&postcount=72 Harvey.
#280
Well Sh-- I must be on a different planet, I figured it was going to be more complicated to fix the cooling on a SVX, must of been mistaken when I figured that it was worth runnig tests and things, didn't realize because I left the sump guard off the data was now all usless (even though tests last year posted with sump guard showed it ran hotter with then with out), all I had to do was drill holes in the pump and the problem will go away. I apolize for trying to fix the problem and having an open mind. One thing for sure I was prepared to listen to everyone suggestion and to a large degree give them a try. I have never had a closed mind but seems that I am wasting my time because everyone else has the answer. Pretty clear its time for me to move on I have more important things to do in life then listen to all the people who are incapable of listening to a different perspective. I clearly understand why other members get sick of the way they get treated. Bye.
Tony
#281
We are just saving you time to do stuff that will probably not work. But I guess you should tackle the fans issue and a more advanced upper pipe. We are all counting on you Tony, don't give up mate...
#282
An apparent self serving lecture rather than advice, is enough to put anyone off. If as has been claimed regarding a lack of under shield, "This results in the radiator having almost, the same pressure acting on both sides of it," was correct, not that long ago all cars would have been useless other than for boiling eggs. In this instance you have been measuring aspects of the problem on a basis of comparison, and an unrelated contingency can rightly be ignored. Your experiments are relevant, not useless and are worthy of sincere congratulation. My impression is that you have been overwhelmed with so much confusing data, much of which has not been supported by factual evidence, that you are up the wall trying to follow a logical course. I apologise for becoming increasingly objective, due to this confused rambling thread, having me alongside you up the same ruddy wall. Remember that you are the one in the driving seat. All us back seat buggers are just that, sitting on bums in a back seat. Yes, take a bye, ignore us all for a while, take time to read the thread through and make your decision based on the evidence before you at this point. Enough is enough. For now, bye bye. Trevor.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 10-22-2009 at 09:20 AM. |
#283
Hi Tony,
I see you are frustrated, rightly so, this multii-faceted problem is very real to you. I for one am very interested in your success. This thread was very interesting to me, as you and others worked together to solve a REAL problem. The fact that Subaru made changes in their six-cylinder cooling systems means that other engineers encountered the same default in the original design. Take a bye, but please return, and post any results or observations publically when you have them. Thanks for starting this relevant thread, nearly 20-pages now. Thanks for sharing all that you have learned so far. Ron
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
#284
Okay Joe has calmed me down and the fact that you guys are offering support has convinced me to go on. Please don't tell me that I wasted my time doing some test unless you can back up the statement with facts not opinions or dreams. I am happy for you to suggest an alternative prospective and that is good but don't do it by dismissing everyone who has a difference of opinion becasue that mean you have stopped learning.
The big point here is that most people such as Trevor, Harvey and Tom are right in the some of there points, for example as Tom & Harvey suggest the top pipe is a major problem, Toms correctly point out that no car has even been cooled with electirc water pumps, that is correct and Trevor says unless we stop the pump cavitating it won't cool and that is correct, if that means drill a few holes to see if we can move the rev point that the pumps fails at then we should tray it. Has anyone tried and electric pump with a Tom/Harvey design top pipe, no. Jack has electric pump but he has the same standard top pipe and Bob said bad airflow through the radiator , now do you can see my point. Not one of these ideas are going the solve the problem but all combined we have a good chace of getting there. In short if you think that you singly have solved the cooling problem on an SVX by doing one thing put your money were your mouth is prove it, other wise feel free to suggest but don't dismiss others as fools. To the problem of cooling. There a re 3 main areas of the cooling system of an engine:- Engine which creats the source of heat and needs to get rid of it. The transfer system, coolent & water pump, Radiator & airflow for getting rid of the heat. We need a plan that looks at each part of the system and improves it. My next step is to drill into the outlet of the water pump under the engine and fit a pressure guage to find out if and if the coolent pressure drops at high reves which would confirm pump caviation. Will let you know how we go. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 10-22-2009 at 01:56 PM. |
#285
Good show mate!
