#271
Re: Building a 10,000 rpm NA engine.
It could be fully open with 75% through the "radiator" for 2-3 seconds and then taper down to 0% if it was a once off burst of engine load / hot head temps. Or if the engine is loaded up (doing laps) it might be going between 50% to 75% flow for example - like a sine wave. |
#272
Car thermostats are definitely not fine Swiss watches Should be easy enough to set up some pots on a stove with water at different temps to see what the response time is. Bill
#273
First, is the mechanical problems in the rods and pistons surviving the high inertia loadings that a piston speed of 25mts per sec. will have at 10000 rpm. The valve gear needs to be very light to try to keep the valves from floating into the pistons and each other at that speed. Secondly, you are treating the torque curve and the Max rpm like two are separate issues, they are the same thing, the HP is the result of where, and how much torque is produced. To develop the HP at 10000 rpm the torque of 350nm would need to be developed at 9000 rpm. At those rpms 350nm is not attainable with this engine. As the engine speed goes up, the time to fill the cylinder decreases, we can use as much duration and sonic pressure as we can, to do it, but the torque curve will become peaky and have a very narrow curve, that will only be usable at 8500 to 9500. Below these rpms the torque wouldn't pull the skin off a rice pudding. We would need a very low diff gearing of about 6:1 and a multi close ratio gear box. It would not be usable for the type of running that the car is to do. You are just starting at a number, 10,000 rpm, then wanting the engine to do it. I believe it is better to develop the engine to have a strong, wide torque curve, that covers the usable range, given the road speed and the gearing, that the car will run. High HP is only good for the drag strip, where the throttle is WFO all the time. On the track you need torque right across the rev range that the car runs. As far as getting the water pump to work at 10000 rpm. It won't do it, it will just spin in its own vacuum. The pump impeller needs to be designed to run at that speed, and then it won't work well at lower speeds. For that speed I would use an electric pump, that can pump the water, without running out of its speed range. Read Issue September/October, Water pumps. The detonation problem that the supercharged cars had, was not due to heat, but to the Igniton timing that Mike programed the ECU to run. Harvey.
#274
The point at which a stat opens and closes doesn't change its 78c on ours as you said Bazza. The stat will start opening (I accept its a slow process) until the temp of the water around the stat see coolant below 78c . When it sees that it stops opening and start closing.
How do I know this well, I alway have a hole drilled in my stat because years ago I was in the snow and I watched the engine temp moving 20c. THe engine would heat up then the stat would open sending a fix of cold water which came from radiator and may have been at 10C, agree that this took a couple of minute but then the cold water hit the stat and it would close again. My wife and I watched this happen at a cycle time of about 5 minutes. The interesting thing is this did not show of the dash temp guage. I need to apolize because I am not explaining myself properly. What normally happens is if the radiator is below 78C then the thermostate will adjust the amount its open so that the mix of coolant it sees is hotter then 78C. It will never fully open if the radiator is lower temp then 78c. The further it is below 78C the less it will open which intern means less flow till it gets to a point like in the snow when it will cycle. My point is the better the radiator / colder the radiator the bigger the problem become from lack of coolant flow. THe cooling ability of the system is litrs of flow times the differential temp. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 09-09-2012 at 07:48 PM. |
#275
Harvey I read what you say and see what you say but in the real world of race engine I don't see it backed up by actions. Nascar engine are limited at 10k is I rememeber correctly and even they want the power out there.
Water pump we are working on but pretty sure the electirc has got a chance of cooling the engine. There flow is rated on zero head pressure. Bazza and I have agreed that we may have to move the existing water pump to be able to control speed of the pump and also take pressure off the timing belt. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#276
#277
#278
Detonation and heat tend to be joined at the hip. A hot engine will detonate far easier than a cooler engine and a good aftermarket ecu has inlet temps and engine temps accounted for - mine for example goes into limp mode above 100'C and pulls timing anywhere outside of the acceptable zone. |
#279
The dry sump will be installed on Bazza car and then we will move onto developing a new top pipe for the cooling. Is important that one stage is completed before we move on. After we develop the top cooling pipe with twin stats we will then start the test bench work on oil flow and coolant pump supply as we have discussed before. What I don't think we mentioned was that we built 2 dry sumps while we were going.
When we get the test bench going it will answer some of the question. After we are happy with the oil and cooling system we will fire up the dyno and run some torque curves. Tony
#280
So using my 46 mm radiator inlet up top with a merge just before the inlet - that's 29mm x 2 (1212 mm ^2) going into 46 mm (1662 mm^2 area)... certainly not rocket science to see that this basic mod will increase flowrate dramatically and reduce the pressure here. |
#281
#282
Wow what a debate, its all good info.
Harvey I don't want to debate back and forward for ever I just want to say that the only way I am going to get this engine to run at 10k is if I beleive its posssiable. Even if its just a wild dream;- I want to fail from trying, not instead, Not try because I might fail. We have a saying at my work, The possiable is easy, the impossiable just takes a little longer. This engine is just part of that rule. Were going to 10,000rpm plane and simply, end of discussion, its going to happen I don't care what it takes or how long it takes me it will happen. Have a great day all. Tony
#283
Now, moving to the torque, even if we have a tapering torque curve it's not an issue, so even if torque peaks at 6000-7000 rpm as long as the power keeps climbing and the torque isn't dropping off to quickly it's still going to be ridiculously quick. This is an example of one of my old setups from about 5 years ago - the torque curve tapers however this car was ridiculous. Low 11s @ the drags, 2nd fastest Liberty around Winton (still to date) and from the apex out it wanted to light up the wheels, so much power everywhere. Drove it as a daily driver for 100,000 kms. Nobody with any sort of clue can say a tapering torque curve doesn't work - it's just utter rubbish. You just don't want it looking like a mound where it comes up peaks and falls straight back down. Quote:
Further find me a bullet proof electric water pump under $1000 which can do the job of the stock pump, 200LPM etc etc. Davies Craig only go to 115 (which I have one of them to run my rear water to air intercooler and I doubt it would even get to it's rating). Further again - adding an electric pump adds another single point of failure, something avoided when you build a car to go racing with. Last edited by bazza; 09-09-2012 at 10:22 PM. |
#284
Here is the computer simulator I promised for the cooling system on a SVX, its excel so play with it.
- Yellow cells are entry. - When the cell turns red it means you are outside of possiable range. - It assumes the thermostate is in place. - The name of the game is to get the highest number in the cell that is headed "Amount of Heat removed per minute in Kcal" the bigger the number the better your engine will cool. - Thermostate opening temp is fixed at 78 may change it so you can install a different opeing temp but lets see how much interest is in it. Have a great day all. Tony PS had to fix file
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 09-10-2012 at 12:14 AM. |
#285
So a few of you have down loaded the cooling simulator, have I caused more confusion or does everyone think its totally wrong.
It would be good to get some feed back or discussion going so we can all agree if I am on the right track. Tony
