#256
Re: 11:1 CR Race/Street Engine build
Debris = fall out from the cam breaking?
-Bill
#257
Thats my guess... the pump inlet is not filtered from the sump...
Tom |
#258
I should data log the oil temps on my car one day and get that info to you. It's remarkable how hot my cooler actually gets regardless of the fact that it's mounted and fed cool air just like the TMIC on the WRX/Sti.
#259
Bummer.... hate to face unexpected issues.
Was it because they are welded/reground?
#260
Tom:
If you kept the oil filter, we should cut it open. That should reveal exactly what kind of debris did the damage to the pump. It pains me to think that all the time I was enjoying that glorious engine at the Glen, it was self-destructing. I really look forward to getting it back on the track. It is really sweet. It was also nice passing some people for a change, even though there was some seriously expensive iron out there with me.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#261
I missed something...Shotgun's 11:1 engine broke a cam and then blew a rod bearing?
#262
Yes, but there was about 1200 miles of street and highway driving and about 100 miles of track driving between the 2 incidents.
Tom was driving the car home from the dyno shop, after tuning, when one cam broke in two. Suspicion was that the cam may have had an imperfection and the weld/regrind process may have caused a crack to develop. The ultra high lift and acceleration profile of the cam caused torque forces that shortly twisted it in two. He got Web to make a replacement and put it in the motor. I continued the break-in process, including a trip down to visit Old Tom in WV, and the trip up to Watkins Glen. About 20 minutes into my third track session, I experienced a sudden engine drop-out which we think was the knock sensor cutting fuel and advance in response to the bearing coming apart. But, I don't know if Tom has verified that the debris found in the oil pump was from the cam, or some other source.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold Last edited by shotgunslade; 05-19-2010 at 10:08 AM. |
#263
That is truly unfortunate. Hopefully all is well with the system cleaned out and a new oil pump. Do you suspect there to be debris in the cylinders? I am crossing my fingers that I wont have to deal with a similar problem in my build.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
#264
dang... well at least the problem is found, I hope that in fixing this problem and getting it back on the road you don't run into anything else! Good luck!
#265
I have at home a broken cam...it broke in two one day like that. I don'T use special cams, pistons..... only a chip, intake from tom, ....
Nightmare is the name of the car... |
#266
Yea Mike... Still kinda dumbfounded by the cam shearing... L/S intake sheared like I have never seen before... No evidence of clearance issues, no bucket failures... Just a freak thing... This was after about 200 miles of break-in and a full dyno tune session.
This engine has proven to be the biggest pain in the ass I have ever dealt with. Between the insane amount of fab time and assembly for all the little custom bits and pieces and the crazy **** that has happened with this thing.... I can honestly say, I am looking forward to not dealing with another one like it Tom |
#267
Maybe a good idea to magnaflux all welded or performance cams before installing? Crankshafts are routinely magnafluxed in performance builds.
Mis-handling or dropping a cam may result in a break that wouldn't be noticed before assembly, but result in total failure in a running engine. Any pictures of the broken cams, or did I miss that?
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
#268
Tom |
#269
Throw some weld, higher pressures, severe duty, bang . I've seen factory rods and cranks with cracks, both gas and diesel, no known reason for these fine cracks, but such can lead to failure. Welded cranks are always magnafluxed, maybe its not routine for cams?
#270
Like I said, it will be too soon before I do another one of these Tom |
