#256
Don't listen to him longass!! I traded him my carbon-fiber prototype trunklid for two models and by the time they got to me they had eaten all the pudding and gotten fat!
-Craig Lowthorp, Flagstaff AZ '92 LS-L, Black on White, 136k SOLD '92 LS-L, Black on Silver, 120k SOLD '01 Legacy Outback, White, |
#258
So, let's get this thang back on track.
![]() What's the good word, Longass? |
#260
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** ![]() |
#262
FINE!!!
![]() I don't really have any "hot" pictures of her (whatever each of you might consider "hot")... But here is a picture of her just before we left for my senior ball last year. Senior Ball And here is a picture of her when we went on a photo shoot a while ago. Sorry, B&W. Photo Shoot Annnnnnnnd if ya don't think she's good lookin, you can **** off!! |
#263
Re: FINE!!!
Deruvian,
Treat her right...I agree with Michael - she should look right at home in the seat of an SVX. She makes me think of what my oldest daughter might look like in another 8 years. -Bill p.s. Okay Chris, can we get back to talking about dyno charts and phase 3 kits? ![]()
#265
Re: Re: FINE!!!
Graphic on the front, centered Graphic on the back, centered Graphic on the sleeve |
#266
Deruvian,
I was just noticing the mods to your car in your signature. You're going to want to change some of that. Some of them are actually horsepower loosers. You should patch that hole back up in your fenderwell--that actually siphons air out of the fender instead of letting it flow in. You probably aught to put the intake resonator back in too in order to insure you are only drawing in fender air instead of engine compartment air..it's not really a restriction. You should use a K&N pancake filter in the factory air box. Put a maganflow high flow resonator in where you took out the factory resonator and remove the primary catalytic converters (the smaller ones on each side). Especially if you are going to put a stage 2 or 3 kit on your car. You want to remove these to decrease the temp at your exhaust manifold. |
#267
longass
lol, sorry i just think its funny to type that, anyways, He is planning to do something similar to me with his intake, so to replace the stock uh, resonator, yeah thats it, for the intake isnt going to really help prevent the induction of engine air, when your filter in 5 inches off the ground, I dont think that engine air will be down there, warm air rises? ![]() Thanks Dustin |
#268
I don't want to reinact the whole discussion of how the air flow around the svx's front end and into the engine compartment, and into the fenders works but I'll give you the short points. The design of the front bumper with the wide slots, the pan under the front of the engine compartment creates high pressure into the openings in the bumper and low pressure underneath the engine compartment. This draws air through the front slots both through the radiator into the engine compartment and around the sides of the radiator into the fender wells. If you open a hole to the fender well in the low pressure area while not sealing the opening into the engine compartment yes it will certainly draw hot air from the engine compartment into the fender well. If you are putting a conical filter into the fender which it sounds like you are...you should be careful to seal around the hole going into the fender. If you cut a hole in the plastic in the bottom it will most likely suck air out of the fender rather than let it in. All that's been discussed before so lets not start it up again in here......maybe in your thread on how to do it would be a good place. Personally I don't see anything wrong with the factory airbox..just throw in a k&N pancake filter and you're good to go. |
#269
Longass, do you know if there ever was a thread about the exhaust resonator's purpose? My local muffler shop informed me that all those do is slow down air flow, reducing the noise. And about the primary cats... California is very strict on smog regulations. I am thinking about removing the y-cat, and replacing the two primary cats with two high-flow cats. This will be essentially the same setup as the stock, but with a new muffler (unsure on the brand right now) and without the y-cat. However, I'm not even sure if this will be legal. I still have to make some phone calls to the DMV, my mechanic, and some muffler shops in the area. If I didn't explain any of these setups very well, let me know. I'll make some diagrams for you. What's your opinion now that I've explained? Thanks for the concern. |
#270
It's the primary cats you want to remove in order to increase flow as well as keep control of temperature. We dont' smog test in florida anymore......but back when we did I driving a 10.2 second mustang. Some of the common work arrounds were to swap back in the factory cat pipes just for the anual emissions test, lower idle to where the car was barely running and thus hydrocarbon output was low, intentionally make your exhaust leak so that half of the ehaust gas never makes it back to the tailpipe. Emissions criteria in fl also varry according to the year of the vehicle. If it's the same in CA you should find that the criteria for your 10 year old car should be easy to meet. If they are inspecting to see that the catalytics are there another common thing was to bash the honeycomb material out of the cat so that it appears it's there but it's really empty. Not that I'm suggesting you do anything of these things, just telling storries about how I've seen people work around emissions tests. |
