Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Engine Management
Old 06-20-2009, 07:27 AM
Re: Hydra Nemesis
I will try and get a picture up today.
Old 06-29-2009, 02:49 PM
Banned
Re: Hydra Nemesis
Picture or explaination?
Old 07-02-2009, 05:41 PM
Banned
Re: Hydra Nemesis
still tryin to fix some things on the SVX before I put my hydra in.
Old 07-02-2009, 06:33 PM
Re: Hydra Nemesis
I will try and get that pic up this weekend. Honestly you cannot miss it though. It is the small vacuum line comming off the back of the passenger's side of the intake manifold
Old 07-02-2009, 07:59 PM
Banned
Re: Hydra Nemesis
how do you tap into it though?? I know where all 4 vacuum lines are but I don't know how to tap into it??
Old 07-02-2009, 08:58 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Hydra Nemesis
T fitting.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 07-02-2009, 10:38 PM
Banned
Re: Hydra Nemesis
any particular size??? aren't the tube from the hydra and the tube on the intake different sizes??
Old 07-03-2009, 08:33 AM
Re: Hydra Nemesis
Yes but you can get some larger hoses that will fit onto the engine's nipple that will stretch out over the t-fitting that should have come with the Hydra. Just buy some new hose and run a small length off the manifold to the T. Then run the line for the unit into the car and run the rest of what you bought back down to the pressure regulator
Old 08-12-2009, 05:49 PM
Dessertrunner's Avatar
Re: Hydra Nemesis
Tom did you manage to sort the unit out with the Air con etc. It seems tha the Wolf guys think there are some smarts between the ECU and the Enviro system.
Tony
Old 08-12-2009, 05:51 PM
Re: Hydra Nemesis
Tony
I did not need to, the units came capable of A/C. Basically all it does is bump the idle (this is programable) and turn on the fans. not much more smarts than that though.
Old 08-13-2009, 02:57 PM
Banned
Re: Hydra Nemesis
wow I feel like a dur dur dah dur I totally just reread your post tom and looked up that part in the service manual then looked at the motor again... wow do I feel dumb... the only small hose similar in size to the hydra one.... DUH! I just bought a new hose and hooked it up. Will be installing maps and mounting the hydra today... WOW do I feel dumb... glad I finally figured it out. Thanks!
Old 08-14-2009, 06:37 AM
sicksubie's Avatar
Re: Hydra Nemesis
Johnybeas,
What are you using to get the Hydra to interface with your pc? I am striking out here with one PCMCIA card after another.. None work with Vista. I am going to get a USB to serial port adaptor to see if that works now because this is getting ridiculous...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 08-16-2009, 05:51 PM
Banned
Re: Hydra Nemesis
Originally Posted by sicksubie View Post
Johnybeas,
I used a RS232 PCI Express card it's just a regular PCI express serial card. The one I got has separate drivers for vista on the install cd, once you get the adapter installed make sure you follow the instructions on the hydra installation manual to the t. I think I have a bad battery and can't start it. It keeps bleeding volts. The hydra is very picky on how you do things and won't let the car start with anything less than what it needs.
Old 08-16-2009, 07:06 PM
Banned
Re: Hydra Nemesis
I got it to start but can't keep it stabilized I had the clutch in and car in neutral, I had to keep pumping the gas to keep the motor running it's almost like it was trying to idle at 0 rpms, also it smelled really rich when it started. Also I noticed that the air temperature seemed really low. it was like -4 when the coolant temp seemed normal at 70. HELP?! I tried callin tom, I can't get a hold of him, do any of you guys who have a hydra have any ideas? I set the throttle positions and did all the set up steps.
Old 08-16-2009, 08:38 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Re: Hydra Nemesis
Hmm seems like the firing order is incorrect... perhaps the wiring harness needs a check.
Tom knows better than anyone else. So better get a hold of him.
