#241
Re: New Shift Kit Developed
Harvey,
When looking at the board which bares the words “Slick Shift” V11”, and which you describe as your final production model, please indicate the components which deliver a regulated 4.5 volts to be switched onto the TCU control line, as per you original text below. Here you specify a requireiment for two regulated voltages. This part of your design has always confused me. Also which resistor is inserted into the A control line? It uses a LM741 Op-Amp configured as a comparator, comparing a regulated set voltage to the Throttle Position Sensors voltage. When the TP voltage reaches 1.8 V the Op-Amp sets to turn on a transistor to operate a DP/DT relay. One half turns the TCUs Torque Control line off the ECU and on to a regulated 4.5V, that it can pull up and down happily. The other side of the relay inserts a resistor in the A solenoids control line to limit its signal to 5%. This action keeps both the ECU/TCU from posting trouble codes.
#242
Would you be willing to put up a circuit diagram?
-Nate '92 LS-L Pearlie |
#243
No. I am sure you can work it out when you by one. Harvey.
#244
Not at this time Nate.
#245
****Deleted****
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
#246
Thanks again Harvey,
My SVX is shifting brilliantly.
#247
I am confident that my money would not buy/purchase, an unadulterated example. I will pass the offer by.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 06-25-2008 at 08:18 PM. Reason: Ad |
#248
Funny you should say that Matt, mine is too.
#249
"The thread has been deleted. RSVX posted up a photo shot of our forums admin panel showing all of Fasters IP's along with a photo of their admin panel with Trevors IP's. Needless to say, Perfect match".
#250
If you want to discuss something with me outside of the scope of this thread, by all means PM me. But to touch on it briefly, you are the ONLY person I hear from regarding this, so yes the masses must truly be speaking. Back to my comment, about your methods and intentions. A response would be appreciated, but is clearly not expected.
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse) -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ) -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ) SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
#251
However, I do agree with Trevor on this point, I really don't see how it was appropriate to share his personal information with any other organization. I understand if laws were broken and there was an official investigation, but for anything less than that I'm very disappointed that you are so easily willing to release this information.
#252
No personal information was shared. IP addresses are public. That is the only information that has changed hands.
#253
I've been looking at it and I think I must have misunderstood your previous explanation. I was thinking that the QC actually generated its own duty cycle for solenoid A. But from looking at the picture, I'm fairly sure I was wrong about that. Unfortunately the technical explanations have become lost in amongst all the fighting. I see an Op-Amp, a relay, a V-reg, a transistor and a few resistors, diodes and capacitors. A fairly straightforward analogue circuit. As you said K.I.S.S. Am I right in thinking that the below is a reasonably accurate description of how the QC works? 1) The Op-Amp circuit causes the relay to close when the voltage signal exceeds the pre-set level. 2) When the relay closes, two things happen: 2a) The torque control line is held high to prevent the ECU from reducing engine power during shifts. 2b) A fixed resistance is inserted into the Sol A line to reduce the voltage (Amplitude) of the duty cycle sent by the TCU. ?
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 06-26-2008 at 08:48 AM. |
#254
Has anyone been able to make a run with the QC to see if there are any measurable performance gains (i.e. quicker passes)?
1992 LSL Pearlie: 108k, 15min/$15 mod, Alternator wiring "upgrade," Power Mode switch, K&N drop-in, 4500k 35w low-beam HIDs, 3000k 35w fog HIDs, lots more planned (pending funds, of course)- 4.44 5spd being at the top of the list. "We laugh at honour and are shocked to find traitors in our midst." -C.S. Lewis |
#255
I am making some 1/8 mile runs as soon as I get my QC,within the next two weeks,performance gains maybe greater since my svx is fwd also I am going to dyno her also.
