Old 09-02-2012, 07:43 PM
Re: Power Mode Selection
Originally Posted by aust92pearl View Post
oh :/ no wonder it didnt work then
i know the jdm ones have the power mode button and the uk ones have the economy button but ours have neither of them
so how does the power mode engage on the aust spec ones
(mine is weird it works most of the time under 80 kph , but no matter how many times i mash the pedal wont engage over 80 )
is there some other way to make it come on without the rom
The Aust PM works the same as the US PM, on the speed of the throttle movement. No other way.
I do have two spare Roms, one for the early pre 95, and one for post 95 Aust models. You have to fit a socket on the board to fit the rom.
Old 09-02-2012, 08:12 PM
ah ok , damn
i would be tempted if i was planing on keeping the auto
but im going 5 speed hopefully before the years end
Old 05-14-2013, 01:06 PM
simboglide's Avatar
simboglide simboglide is offline
Originally Posted by Coan View Post
Ok I took a few pics to see if I'm doing this right.
First off, are these little plastic squares on the side of the connector the release tabs?
Here is where I'm inserting the nail/screwdriver:
And in this pic you can see that the tip of the nail is stopping on top of the little plastic square shown in the first pic:
Am I doing this all wrong? lol
Old thread, I know.... Is that a 10 pin plug? I ve pulled all three of the plugs out of my TCU and see no brown wire in 6th position, but... it looks like i have 2 16 pin connectors bookending an 8 pin connector.. GOING INTO A SILVER "BOX". Am I foraging in the wrong area?
Old 05-14-2013, 01:26 PM
bishop bishop is offline
your looking at the ecu if im not mistaken.
Old 05-14-2013, 03:23 PM
simboglide's Avatar
k, the other box it is "mounted" to has large blue plugs.
Old 05-14-2013, 07:56 PM
simboglide's Avatar
Eh, I found it, just overlooked it, anyone have a picture of the female pin connecter so i can see which way the lock tab is positioned?
Old 05-14-2013, 09:32 PM
simboglide's Avatar
Jimminy Christmas...I found the slot below the connector where the screwdriver should go in to depress the tab, no go!! grrrrrrrrrrrrrrrrrrrr
Old 05-16-2013, 06:09 PM
simboglide's Avatar
Anyone have or care to remove a connector and take a photo so i can see how the lock tab is situated?
Old 05-16-2013, 08:30 PM
Coan's Avatar
Coan Coan is offline
Alleged User
If you are trying to remove the pin from the connector, those pics of mine that you quoted are good step by step instructions. Mine was jammed because I did it incorrectly the first time by trying to insert the nail into the side if the connector.
It may take some wiggling, but it should come out if you follow the pictures.
Jon
1997 SVX LSi Bordeaux Pearl
1995 SVX L AWD Polo Green - 277k miles
1986 Pontiac Fiero 3.4L Twin Dual Cam V6
Old 05-16-2013, 09:29 PM
simboglide's Avatar
I saw those except i think the slot you actually needed to release the tab is on the other side of the connector, just below it, as it were. That's why i want a picture of an actual terminal. I don"t want to destroy the housing trying to get a 17 cent terminal out of it.(great pics btw, just wish i could have saw the released terminal)
Old 05-16-2013, 09:31 PM
simboglide's Avatar
Or are you 110% sure the lock tab was on the side you had the nail in? Because i have a jewels screwdriver and did run it all the way through and no, it did not release it.
Old 05-16-2013, 09:52 PM
Coan's Avatar
Alleged User
Yeah I'm sure that the way the picture shows it is correct. I remember because I stuck the nail in the side at first and broke part of the housing right next to the release tab which is why I was having so much trouble with it...
Jon
Old 05-16-2013, 09:54 PM
simboglide's Avatar
Alrighty... givin it another whirl right now.
Old 05-16-2013, 10:00 PM
Coan's Avatar
Alleged User
IIRC, you don't need to stick the nail/screwdriver in any father than my picture shows, and once it's in there, just wiggle the wire in and out as you release the tab with the nail.
Jon
Old 05-16-2013, 10:25 PM
simboglide's Avatar
Still have some fiddling to do but,,,for future reference,,, a flat tipped nail goes through your finger easier than it comes out.
