Old 06-15-2013, 05:49 PM
Scimitar Scimitar is offline
I GOT MY A/C FIXED!! For some reason I thought the car was still running R-12, and then it hit me on Friday that R-12 systems don't use quick release fittings, so someone in the past must have converted it. Soooo I had a friend with some gauges and a vacuum pump hook up to it... we pulled it down and let it sit for about an hour with no leakage and then put some 134 in... pulled the gauges off and it starts hissing out the valve. No wonder there was nothing in there! I tightened the valve and it blows ice cubes out of the vents.
Needless to say, I am quite pleased! Now I gotta get a new cruise control button... Anyone have an extra switch set lying around they wanna get rid of?
Old 06-15-2013, 06:22 PM
bishop bishop is offline
This was a 2 day endeavor but im so proud now that its done. Washed, Clay barred, Buffed, Polished, and finally waxed.
nice reflection from the rear deck, ignore the key marks that were there before i got it
Roof has a lot of flaws and failing clear coat.
Dat ass.
Old 06-15-2013, 07:17 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Is that the original pearl white paint? It looks so milky white!
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 06-16-2013, 12:34 AM
I'm honestly not sure, certain parts look pearl, certain parts look plain/metallic white, and there are a few areas with chipped paint that is so thick i just dont know.
Old 06-18-2013, 10:02 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Put a new headliner in myself. Decided that my car needed to be a lumberjack, like me.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 06-18-2013, 10:18 PM
Oh well er,,,,,,, that looks er,,,,,,,,,,,, well no wrinkles.
Old 06-18-2013, 11:08 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
You have map lights in the back....?
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 06-18-2013, 11:32 PM
reberto reberto is offline
Sunroof looks to be a non-OEM one too...
Old 06-19-2013, 12:21 AM
Blew the clock fuse under the hood 3 times in 1 day..
Ripped apart the sunvisors and the interior trying to find the burnt wires..
Found out that previous owner had already cut and removed the visor light wires.
Traced problem to having someone sitting in the front passenger seat.
Front passenger seat is manual, so scratched my head and looked at confused.
Then realized that I had installed LED floor lights under the seats to light up the back floor...
Wire got itself caught in the gear for the folding of the seat back...
It stripped off the shielding and was grounding out on the metal gears inside there when any pressure was put on the back of the seat..
Hours wasted tracing none existent wires through the ceiling and door pillars, only to find out it was a simple mistake on my part with where I ran the wires for my LEDs..
TLDR:
Totally worth the 3 blown fuses:
Old 06-19-2013, 04:09 AM
ShaneHobson ShaneHobson is offline
Replaced the plastic headlight assemblies (JDM car) with glass assemblies from a NZDM car. While the lights were all in bits, fitted 6000k HID kit to the low beam lights.
Drove home tonight in the dark, wow !
What a huge difference it makes.
Not sure if it's the glass (the plastic was in poor shape) or the HIDs, either way well worth the cost.
Set of glass head lamp assemblies $NZ150
HID kit, ballasts & H1 bulbs $NZ99
Installation $NZ120
The glass headlights were half price because one of them had a small hole in the glass. It was in the fog light position (no fogs on NZDM cars) so the garage was happy to fit them and pass a safety inspection once I had put clear 3M bonnet guard over the hole so stop moisture getting inside the headlight.
Old 06-19-2013, 05:22 AM
B 4 You's Avatar
#lolsvx
Yeah... And yes the sunroof is not OEM. I also have no lights in the front but after taking the headliner apart I realized that there is no room for anything else up there.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 06-22-2013, 09:01 AM
Tomodachi Tomodachi is offline
If you not mind me asking? How much did you pay for all four struts? The reason I ask is I live and work in Japan and the same parts are more expensive here!!
Thanks,
Charles Yost
Old 06-22-2013, 09:20 AM
Pulled apart my front brake assemblies to try and find why they were squeaking, both show signs of high heat, one shows signs of un even wear. Time for some reman calipers.
Old 06-22-2013, 07:54 PM
Huskymaniac's Avatar
Uses the ignore feature
Replaced radiator, installed transmission cooler, oil change, replaced brake fluid, replaced fuel filter, drained and refilled ATF, replaced accessory belt, fixed rattling heat shield, replaced a dead bulb.
Tony
Old 06-23-2013, 05:55 PM
Drove home from the Dragon Meet....
