#181
Re: Mid Engine SVX concept.
Don't want to have a top engine mount, so have beefed up the gearbox one with a new heavier design.
Its tacked ready for welding when the other parts are in place. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#182
Aren't you done yet? Come on!
Seriously, awesome work man. Looks great.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#183
Updates???
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
#184
Sorry guys have been working just not posting,
Here is a 3d pdf of the final brake, disc, upright & wheel assembly. Hope it all makes sense. Tony
#185
Okay brake capliers are wilwood 120-4322 &23 they are the type used on a GT III and NASCAR here are the details.
"The cast aluminum GT III Caliper is ideal for NASCAR Nextel Cup, Busch GN, Craftsman Truck, ARCA Supercars and SCCA road racing. The double bridge bolt design is extremely rigid and provides drivers with a firm, responsive pedal and superior stopping power. The differential piston bores have been positioned to maximize clamping force, provide even pad wear and enhance caliper stiffness. Weighing only 8.4 pounds, the GT III incorporates stainless steel heat shielding throughout the bridge area and piston bore facing, along with heavy duty pad abutment plates. The GT III utilizes the thick GT pad (11.3 cubic inches, 1.10” thick), and is a direct bolt-on interchange with the 5.25” mount GT Series calipers. Wilwood’s exclusive short track pistons are available for the GT III Caliper. Recirculator tubes are also available. 1.88"/1.75" piston diameter. 1.38" rotor width. " Front and back of the car will have the same calipers, same size disc and wheels. Discs are the same as late STI 13in or 326mm diameter. At this point I am aiming to run ABS as you can see fromt from the plan. Tyres at this time are 275/35 - 20in, there has been a fair bit of debate on this issue. Bazza and I came to blows on this point as he beleived that 275/35 on 16 or 17in rims would give me faster lap times. I don't agree, happy for anyone to express a opinion. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 03-10-2013 at 10:28 PM. |
#186
Unless the 20" wheel is designed to be lighter AND have less rotational inertia, 16/17's will be faster. And if the 20" wheel is designed to be better than a 16/17" wheel, the 16/17" with equivalent design would be faster.
You can't fight physics. Upright assembly looks cool though! |
#187
#188
Of the weight and more specifically, how far away it is located from the center of rotation.
The tires themselves should be more or less equal in terms of mechanical grip. But the 20" tires take more energy and therefore time to accelerate and decelerate. Moment of inertia I=mr^2, where m is the mass and r is the distance of the mass from the axis of rotation. The mass I'm referring to is that of the tire and the outer barrel of the wheel |
#189
In Australia our V8 supercars went from 17in to 18in and they say they expect lap times to be quicker. 24 hr Le Mans cars are 19in and the rules stop them going to 20in, as I understand it NASCAR tyre outter diameter is simlar to 20in with 275/35.
So I can't get my head around what is the right thing. THere has to be a gain from a larger over all diameter other wise they would need rule to stop people putting smaller tyres on not larger. Its confusing ![]() Tony
#190
Does it have anything to do with engine speed, gearing and overall speed? I have 19's on my Svx and that adds 10kph at 100kph at the same revs that would yield 100kph on normal rims
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
#191
As for rules dictating size, there are other, non-performance reasons too. Quote:
#192
Agreed with neverlift. The rule on wheel diameter is primarily there to limit the size of the brakes. Kinda like in gravel rally. 15" diameter wheels. You have squeeze some punny brakes in there. But a good rule of thumb when it comes to brake size. When your at speed, if you can slam on the brakes and lock them up, then you dont need bigger brakes. R-compound tires and in many cases, non power brakes would require larger brakes to aid in it.
A great example of this is the stock SVX calipers. Most people this our cars have crummy brakes. And up until recently, I would agree with them. Until I put on a set of quality pads. Even with my r-spec tires, i could lock up all 4 wheels. 80 to 0 mph was damn good. ... Sorry, getting off topic here.. In terms of wheels, you only need to go as large as your brake system requires for clearance. Yes, you get less rotational inertia from the lighter tire/wheel package, but you mainly gain a more compliant tire carcass. A tire needs to have sidewall. If your tire looks like you painted it onto the wheel, chances are you will be All over the track. The trick is finding out what is Best for YOUR car and the track conditions. Bumpy track, more sidewall. The tire can conform better and take more abuse. A silky smooth track, less sidewall for crisper steering input. Its really a game of trial and error, and in Many cases racing regulations. ALWAYS check to make certain you are in compliance with what ever racing sanctioning body you are racing with. This also tends to bring up the thought of tire width. Most people tend to think a wider tire is better. This is rarely the case. A crazy wide tire on a car is there to cover up bad handling characteristics. Be it bad camber fluctuations in suspension travel, bad roll center, or akerman angle. A wide tire has far more surface area in contact with the tarmac at any given time. Most think, "Ahhh, that means more tire to grip with!" yes and no. Yes, there is more tire. However the pressure per cm of that contact patch pressing down on the road is far less than that of a skinnier tire. Thats why in tarmac rally, our tires are not all that wide. In reality, that fat rear tire is not giving a heck of a lot more grip that the front. I talked to a few fellow racers on this, who quickly bring up formula 1 as an example. Huge rear tires! However with out the downforce to squish all that rubber to the ground, they handle like absolute crap. Now take a look at other formula classes. Similar cornering speeds, less areo, thinner tire. Most of our cars will Never have that sort of downforce aiding us in racing ![]() In the end, it all comes down to choice and track conditions. Wide, skinny, lots of sidewall, little sidewall. Get a set you happy with and experiment over time. Talk to others with similar setups and so on. Cheers SMC |
#193
At the end of the day, the rubber is the link between racecar and track and you only have so much grip for X amount of rubber. Last edited by bazza; 03-12-2013 at 12:32 AM. |
#194
Now I am confused,
Would it be different between a front engine car and a mid engine, can't argue with Bazza's lap time point, also difficult to understand why most of the race cars use a higher side wall profile. Anyway from my point the mid engine project is a work in process so I am sure I will try different rim/tyre sizes over the next couple of years. The main issue is to design the body and suspenion to fit the biggest tyre I think I would use then go down from there. Easier to go that way then trying to go larger later. Mesuared the Brakes etc on a rim last night, looks like can fit a 18in rim over the calipers, 17in might be to tight. Given that the V8's went to 18in for more choice that sounds like a plan down the track. Tony
#195
Getting a bit frustrated with the project, need to get the lugs/pivot point for the laterial arms away from the discs a bit better which then means the plate I am using is not thick enough. Currently its 75mm and I need to be 100mm. Current thought are to do up a bearing hub simlar to what is on the newer STI's. It looks like it will work just more cad time getting it all sorted out. On the postive side the bearing pocket is quicker to cut on the CNC lathe then the mill, also the new dsign for the main upright is a lot simpler which means it will require less machine time on the mill. Will post the new design when I get it sorted. I might be asking a bit much as I am trying to keep the Abs sensor as well.
Tony
