#181
Re: Hydra Nemesis
You are correct, the Hydra communicates with a computer via a DB-9 Serial Port:
![]() You can either pick up a cheap old laptop that has Serial Port interface or you can buy an expansion PCMCIA card (which is what I did) for newer laptops that no longer support that interface. I picked one up for around $55 shipped, the reason I went so expensive was I wanted to make sure that the port was fully addressable and could emulate RS232 protocol (which the Hydra needs), so I went with a proven brand. My MAF is still connected and inside the car ![]() Not sure what Tom or Bobby did with theirs, but I am keeping it there for the time being... one of the positives is as you pointed out to pass emissions easier... you can simply unhook Hydra and hook up your old stock ECU and off you go (granted your using stock injectors and so on). -Sov13t. __________________ ![]() |
#182
Re: Hydra Nemesis
What's the max limit for power on the stock injectors??
Also, is a for sure thing that if you are not running the stock ecu that you will not pass emissions?? what happens if you turbo and need to pass emissions then??? One more thing, I'm not sure what serial port connectors have it but I know when I worked at staples we had a few converters from serial to usb for older printers to be able to connect to a newer computer that is lacking that card. Would this work?? Last edited by Johnybeas; 01-23-2009 at 09:46 PM. |
#183
Re: Hydra Nemesis
Max limit for stock injectors and fuel pump is said to be around 240-250 bhp as far as I know. (can someone confirm?)
Running a non stock ECU will probably mean you have it tuned for max power... as such it will most likely be not environmentally friendly ![]() The creators of Hydra EMS warned users not to purchase USB to Serial converters as they are not fully addressable ports... but simply simulations of a port. Hydra needs back and fourth communication at a fairly high speed. -Sov13t __________________ ![]() |
#184
Re: Hydra Nemesis
I believe the Hydra will pass OBD-I emissions, as they don't require plugging into the ECU. At least my OBD-I smog check here in Reno is just a visual check that the CEL is not lit, and then a tailpipe sniffer test. YMMV.
OBD-II is right out... I have to swap my Hydra for my stock ECU that's been remapped for blow-thru MAF on my WRX to pass emissions. As far as the USB/Serial adapters, like Sov13t said, they usually just emulate the TX/RX lines on the serial port, and not the full RS232 chipset. My guess is that the Hyrda uses flow control, RTS, etc... basically all the pins in the DB-9, instead of just the 2 or 3 pins the USB adaptors simulate. And just one not on the MAF sensor and the Hydra... I'm not sure how the SVX Hyrda is setup, but on the WRX Hydra, the Hydra uses the temperator sensor built into the MAF sensor for intake temp. So you still need it hooked up. Lots of people just tuck it into the fender well or somewhere else out of the way to just read ambient, but I'm using mine in-line with the intake to read post-intercooler intake temps.
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty |
#185
Re: Hydra Nemesis
With the base maps there is no temperature correction. Users will need to fit an Open Element GM IAT sensor to their intake and have it taken care of.
You can have the tuner, tune the car to pass emissions on the aux fuel maps. It will pass emissions if it is done right for OBDI cars. OBDII will need to use the stock ECU to pass. Tom Quote:
#186
Re: Hydra Nemesis
good info guys! thanks! I'm getting really excited! I think I might be looking to try and purchase this in march or April! I'm stoked!
#187
Re: Hydra Nemesis
I had another question, do the base maps push the red line like the ecu tune chips did?? I think a higher red line would really help, when my buddy who has an integra and I go cruise it seems like around the time I'm shifting to third he catches up and gets that nose lead because he doesn't have to shift as soon.
#188
Re: Hydra Nemesis
<picard>
#189
Re: Hydra Nemesis
![]() Quote:
The Hydra is nothing like the stock ECU in terms of rev-limiters and such. In fact (correct me if im wrong) but it requires a special TCU chipset from YT just to be used with the 4EAT. This is only recent also. It originally HAD to be used with a MT. Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few ![]() ![]() ![]() 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold ![]() 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
#190
Re: Hydra Nemesis
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
#191
Re: Hydra Nemesis
Tom |
#192
Re: Hydra Nemesis
I am going to be bringing the Hydra to Reading. I will be offering to do a quick install in people's cars so that they can experience the differences they should expect with it. I think this is the best way to show people what it can actually do for them
Tom |
#193
Re: Hydra Nemesis
OMG! Will you have the school bus by then so you can offer a transport service when people get overly excited by the new-found power?
![]() ![]() -Bill
#194
Re: Hydra Nemesis
![]() Tom |
#195
Re: Hydra Nemesis
So the hydra has Check Engine Light Control, but I was thinking I saw you say that it won't have error code capabilities. Is this correct or did I read something wrong?
Thanks
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." |
