#1816
It took me a few minutes to wiggle it out at the junkyard.
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
#1817
I managed to clean it up and ziptie a lot of the wires so they'd be out of the way, and I'm fairly confident I won't kick anything loose when I finally drive this thing. Depending on how far I want to take the restoration, I may eventually pull the dash and column out and replace the entire bulkhead harness, as I do have an extra. I did this when I EJ205-swapped my old Legacy wagon, and it was nice to clean up and secure the wiring to my satisfaction before hanging the dash back on. The position of the pedals is going to take some getting used to. I definitely won't be able to comfortably drive the car in work boots. Maybe I'll pick up some slick driving shoes.
1994 SVX- 5MT, Deltaspeed, Stebro,Work VSXX 1994 Legacy GT 2001 Forester 2002 Impreza WRX 2005 Impreza WRX STI Need parts? |
#1818
Did both my 02's a couple weeks ago, much better on the highway.
Cleaned the maf, slightly better idling. Re-soldered the maf, engine eventually re-learned and is now idling smooth again. Adjusted tps, shifting is much smoother.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
#1819
Forgot to mention, rolled over to 171k, bought the car at 162
#1820
I pulled the turbo out of my '92 Legacy Sport Sedan to fix a small leak in the oil return line that was dripping on the exhaust. (Amazing how Subaru always seems to "engineer" the spots where oil leaks occur so they drip right on the exhaust!) I had the car up on ramps so I could work underneath and a jackstand holding the exhaust up while I reconnected it to the turbo.
After I completed all the work, I backed down off the ramps but forgot to remove the jackstand (!) A moment later there was a big crash and within minutes all my engine oil was running all over the garage floor. By then it was 3 a.m., so I said a few choice words, threw some rags at the puddle, and went to bed. Still not sure what I broke-- whether I punctured the oil pan, cracked a valve cover, or what... The moral is, if you're working on your car at 3 am alone after a full shift at work, dumb mistakes are more likely to occur! |
#1821
Getting closer and closer to being able to lay down the clear coat
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
#1823
Installed Earthworm's poly front sway bar bushings yesterday, as well as new WIX fuel filter and a new accessory belt cover.
Old vs new: What was left of my passenger side bushing, which caused mad clunking and "gangsta lean" as my friends liked to call it: New ones installed: Car handles much better now.
#1824
Met up for lunch with Mark (INVADR)!
Had a great time gabbing over our spaceships!
ARMANDO 1992 SVX LS-L "Black Beauty" 292,500K (purchased April, 1997 w/65K) http://i1259.photobucket.com/albums/...psz1xmhtdo.jpg 1992 SVX LS-L "Blanca" 214,000K http://i1259.photobucket.com/albums/...pskv0odesa.jpg 2004 Mazda RX-8 http://i1259.photobucket.com/albums/...ps7vggfwfu.jpg 1974 Mazda RX-4 http://i1259.photobucket.com/albums/...psentjrygb.jpg Last edited by AlcyoneSVX; 04-25-2013 at 03:02 PM. |
#1825
The good news is that running over the jackstand in my '92 Legacy caused no apparent damage-- my loss of ALL my engine oil within minutes was caused by not getting the cam cover/support seated and sealed properly. Off comes the turbo and the exhaust again! At least it wasn't a punctured oil pan...
#1826
My starter finally gave out. I removed it and opened it up. The commutator and the gear looks fine, a little dirty but the brushes are shot. I could not find any replacements, so I'm buying the whole thing from Autozone, $79.99. Not bad, considering I'm doing all the work.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. Last edited by dannmarr; 04-26-2013 at 06:55 PM. |
#1827
just had my alternator rebuilt today at my buddys shop and with discount it cost $66.29
Teamwork makes the Dream work! Last edited by lightspeedrobot; 04-26-2013 at 06:53 PM. |
#1828
I didn't see any point getting a new transmission when the tires on the car are 3 different brands, and even though their sidewalls claimed to be the same size, none of them looked remotely similar to each other. So I figured before I risked burning up the replacement trans, maybe I should get all 4 tires the same brand and size. Fortunately for me, a friend of mine is moving to Montana in July, and offered to sell me his Michelin all-seasons that he was using for winter tires on his Mustang (his logic is that Montana's winters are just a *tad* more extreme than Virginia's, and his 650hp Mustang probably wouldn't do so well). While the tires were off the wheels, I went ahead and took care of the ugly chrome too.
The gold is a brighter than I wanted, but some brake dust should take care of that |
#1829
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
#1830
That was my thought too, and I had plans to go find one at a junkyard yesterday - but, as I stated above, I didn't want to risk frying the transfer clutch because the tires weren't matched. I figured since the car is driveable right now, albeit annoying, the transmission could wait another couple weeks.
