#166
Re: Gearshift Maps
Ya a piece of wire would do the same thing. The spst switch won't work though. The way it's set up the dip socket is always active. Moving the resistor isn't activating the dip socket it's deactivating the surface mount. There may be another resistor that can be removed to deactivate the dip socket but I don't remember off hand.
You could always use one of my multitune adaptors to switch between the upper and lower half of a 512 ROM. Quote:
#167
Re: Gearshift Maps
Presumably your multitune adapter just switches pin A15 between Vcc and Ground?
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
#168
Re: Gearshift Maps
more or less. The multitune adaptors are a pretty slick way of doing something pretty simple. The high address pin is pulled low and an input is provided to send +v to override it to a high. The input is voltage regulated so any +v will do. This allows the switching to be activated by other electronics in the car instead of a person flipping a switch.
#169
Re: Gearshift Maps
okay, so i've been lurking in this thread for awhile, and i'm not afraid to admit that the programming is way over my head, but I wanted to ask a few questions. Did anyone ever decide if there were any differences between the US tcu as far as year to year changes, I know there was mention of a seemingly pointless mod to the overtemp 2nd gear in the uk tcus. I ask that because I am curious as to the base code that LAN is using for his ecutune controller. Also, did I hear that the original trigger was 244f for the at oil temp light? And finally, how significant is the difference between the low pressure maps on based on the normal and power maps? I have driven my svx at very high altitude in summit county, colorado, and I remember it shifting noticibly different, but i always thought it was my imagination until this thread got going.
Finally, I want to thank you guys for going through all this, because It can make such a huge difference in performance. I mean, many toyota models use the same engine and transmission, but shift differently and it gives the car a completely different feel, so this is a really good way to tweak the car without actually making any mechanical modifications.
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
#170
Re: Gearshift Maps
http://www.subaru-svx.net/forum/show...9&postcount=89 The blue line on the left is normal mode. The magenta line on the right is power mode. The low pressure modes are in between. I think the proposed mod with a turn switch and resistor network would be a cool thing to try. It would just need a little experimentation to find the right values for the resistors. Quote:
#171
Re: Gearshift Maps
Phil, the code you have from Nomake is the code used in the 94 and 95 (and 93 and maybe even some 92s). I pulled the code off a 12p labled ROM again and that's what came off it. That's where the confusion came in when I was looking for my orignal basecode. The question is how early did the 12p ROM start? I'll send you the bin from an 11p ROM and a 96 ROM soon; I've just been busy.
#172
Re: Gearshift Maps
#173
Re: Gearshift Maps
My 96 CDN svx will allow the torque convertor to lock as soon as the engine reaches normal operating temperature (outside temp 20 C to -30C no difference). Which for me is about 2 minutes of driving from my house (all uphill). However, for my 92 JDM in need to be driving at least 20 minutes before the torque converter locks up. I found the same with my son's CDN 92 when he had it. Programing OR were there revisions in the 96 transmision oil pump rate to increase the transfer of heat in the radiator to the transmission oil and/or was there a huge difference in the flow restrictions in the earlier radiator. My sense is that while pump rate and restrictions may contribute it is most likely programming. Peter
1992 (JDM) CXD Ebony Pearl 90K km written off hail damage 1996 (CDN) Lsi, Polo Green, 296,000 km 2009 Legacy Spec B |
#174
Re: Gearshift Maps
AFAIK, the US OBDII requirement was focused on emissions related systems. I'm sure that we still have to 'bow three times and turn around' to get codes from the '96 transmission. Charl |
#175
Re: Gearshift Maps
While targeting emission systems and related functions, the major part of OBD2 was the standardization of the diagnostic connector and its location, as well as the standardization of many of the diagnostic trouble codes. I am sure that the tcu was tweaked to allow communication by a different style of diagnostic tool, and they changed the codes from basic numbers (like 13) to the new style prefix (like P###).
#176
Re: Gearshift Maps
I wouldn't sweat that line of thought much. I imagine Phil already knows the answer to the question you guys are discussing. I sent him the firmware for the 96 svx select monitor cartridge the same day I sent him the firmware for the 92 svx select monitor cartridge and he dissassembled them both the same day. I'm sure he'll post the info on the com commands and codes when he posts the info on the parameter locations and conversion functions.
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 04-04-2009 at 09:32 AM. |
#177
Re: Gearshift Maps
While what you say about standardization is correct, so is my statement that the Requirement focused on emissions systems. Contrary to what you are sure of, there is no transmission information available through the OBDII connector in our 96. Transmission codes must be retrieved in the usual way. Perhaps yours is different, but I suspect you don't have one. Charl |
#178
Re: Gearshift Maps
come on now guys...
No need to get defensive or hostile in this thread. There are no points for being right here. We are all wrong, frequently and it never helps to beat people over the head with it when they are wrong. You'll notice this thread has no numbered lists of why one person is right and the other is wrong, point by point trying to take the other peson apart. Let's keep it that way. |
#179
Re: Gearshift Maps
You are correct, i was just adding a little more info, meant to come across as a guess to the differences, which i obviously don't know. And you're right, I don't have one, that's why I am excited to see what the differences are. And of course, the idea behind obd2 and for that matter obd was emissions related, I'm just thinking aloud.
I'll go back into lurking ![]()
#180
Re: Gearshift Maps
Try to practice before preaching. From where I sit, you are the one overreacting and posturing. Nobody was defensive, hostile, or trying to take anyone apart. Sharing correct information was my objective throughout. Your motives aren't clear to me. Charl |
