#166
Actually, looking at the Flickr thread in Bob's signature, I notice the new exhaust headers.
Bob, did you flow test the factory headers? Did you form a view on their efficiency or did you just replace them becasue you could? You would have noticed, as I did, that the rear most exhaust port has a lot further to travel than the other two in each head and I was unsure of the implications of that. Matt |
#167
Matt,
As good as the stock exhaust manifolds are, they're still a compromise based on packaging and the need for long, trouble-free existence. There are gains to be made in this area! -Bill
#168
Sorry, but here is the scan.
Anybody who can help resolve the torque dip would also be appreciated. It all could point to the timing. APologies to all those that have seen this before. |
#170
I haven't seen my WRX dyno plots in years...that was 7 year ago after all. As far as the 3.3RS dyno plots, Jack is reluctant to release them. So that is beyond my control. IIRC a bone-stock WRX made 175-177 whp on their dyno, so my minimal mods added a few hp. I suspect that the swap to full synthetic didn't hurt either (engine and driveline). Reply by longasname --- That's a shame; they would be interesting to see but they are his and he certainly has no responsibility to share them. Just be warned that someone is running around using your wheel hp readings to try to make a case that the factory engine management is seriously flawed and that there is 60-70 crank hp to be found by installing stand alone engine management on a stock svx. N.B. One must assume that Jack is the name, in case confusion occurs and someone here becomes blamed.
#171
The second one I'm getting the feeling was directed at TomsSVX. Could be wrong, though. Hard to prove intent when someone is trying very hard to be inconspicuous. |
#172
Well I think that Bob is answering well and clear when asked direct questions. It also appears to me that he is new to this forum and aware of this newness, and does not want or need to be caught in crossfire between members who are sniping at each other because of what I will call "issues"
Nomake I did say in a reply to you elsewhere that we need to be cautious in evaluating where an untapped 70 horsepower might be coming from, and the cost of extracting it. Even so, it is still well worth following this line of thinking and seeing where gains can be made. This is the way we will make progress. It would be good if we could continue beneficial progress for all of us without descending into the sticky realm of unnecessary personal slights and I'd like to thank YT for recognising this and stating his case. Joe
#173
I do have to agree with Mike. Leaving the engine stock, and using most of the stock components, you will not see 70whp switching to a stanalone. This engine was prepared properly and outfitted properly for Jack's application and I think Bob did a great job doing. Thus they reaped the benefits of having a system tuned extremely well to their application specifically. At no time did I reference that there would be such a substantial gain in power from a SA alone. My point restated again, an ECU that is tuned very well to match the outfit, will provide more benefits.
Tom |
#174
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#175
Not to mention we started with an engine that was +/- 82 lbs. heavier than the EJ25 that came out of the car, so part of our goal was to get the front end weight to the same as/ or lighter than stock. The headers are 304 stainless and are quite light compared to OEM. We are currently about 5 lbs lighter than when the car had the EJ25 installed, thanks to creative gutting, lightening, and relocation of components from up front. If we ever come across a GC8 WRX hood (aluminum), there's another 20 or so lbs off the front end. We're just trying to alter the front/rear distribution and overall weight for improved handling, which is one of the car's strong points when compared to the average caged STI (3300-3500 lb usually with a heavy front bias). |
#176
If he ends up trying the modified intake manifold route rather than the ITB's first, we'lll delete the IRIS altogether, and I suspect that 'dip' can be tuned completely smooth. |
#177
Bob,
Any chance you might be willing to offer the merge collectors for those of us fabricating their own SS headers? -Bill
#178
We found a significant power increase on a standard engine with the 1.75" primary tube headers, into two 2.5" secondary tubes, merging into a single 3" main exhaust system. One can imagine that this exhaust further complimented....and was complimented by, the larger cams we now have. FWIW, I think that 1.625" header might be a better choice for rallying, and a 2" merge collector tapering out to 2.5" secondary pipes will fatten up the torque compared to the road-racing setup that Jack's car runs. My own 'vintage' rallycar runs a relatively small header with longer primary tubes so I have a wider power band rather than a peaky one. On your engine, you have larger cams, yet you are running an exhaust that is barely more efficient than standard. Perhaps this is the 'cork' that is not letting you extract full power from the camshaft upgrade. Overlap tuning from the increased duration while running with non-equal length factory headers will be virtually non existant. Just my observations, maybe there's a bit more untapped potential still there. Last edited by RallyBob; 03-26-2008 at 10:25 AM. |
#179
My own design is somewhat of a shortcut, but is infinitely easier for me to construct. The central 'cone' or 'pyramid' section is not an integral part of the collector, but rather is welded directly to the ends of the primary tubes. Then the collector is welded onto the primary tubes after the 'cone' is metal-finished. As seen here: Note that the one outer collector section shown is merely tacked in place here for test-fitting. Normally I weld and finish the collector itself on a bench, then weld it to the completed header after-the-fact. |
#180
-Bill
