Old 02-04-2009, 09:07 PM
Re: Power Mode Selection
Try getting the car up to about 45 mph, then let off the gas completely, then mash it to the floor. If the power light doesn't light up then, you probably have a problem.
The power light isn't flashing when you start it, only lights up? Just making sure since it blinks to show a transmission error code
Old 02-04-2009, 09:15 PM
AyeJaye's Avatar
AyeJaye AyeJaye is offline
Pretty sure it just lights up with the rest of the indicators, but I'll watch closer when I start it up in the morning.
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle
06 Hyundai Sonata GLS, 77K miles
Old 02-04-2009, 09:19 PM
You would notice if it flashed, it flashes 16 times at start up if there is a code. I just wanted to check as it would help with diagnosis
Old 02-05-2009, 07:38 AM
AyeJaye's Avatar
Ah... Yeah, I'm pretty sure I doesn't flash 16 times.
Old 02-05-2009, 02:00 PM
AyeJaye's Avatar
So yeah... It works just fine. I just hadn't had any reason to slam the pedal to the floor yet
Old 02-05-2009, 02:19 PM
It is programmed in such a way that it will start Power mode much easier at low speeds than at high speeds.
You will notice Power mode comes on very easy if you floor the boot at 30 mph.
It might not come on at all if you hit the carpet at 80.
Old 02-05-2009, 06:24 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
It will! Just stomp on the gas, let your foot up fast and stomp again... Activates the power mode when you do
Old 08-09-2010, 10:03 PM
Old Fogey
Think I'll revive this thread from the dead for 2 reasons:
1) Thanks to Ron, NeedForSpeed, my '97 now sports a JDM Power switch, in the stock position. Even lights up! I'll confess to being a little skeptical regarding it's benefit, until I drove the car! Definitely peps her up. Ron also installed the Shift Lock release button from my '93 while we had her disassembled. Thanks again my friend!!
2) I also have a question regarding the "Power" lamp in the dash, missing in this MY. How are the trouble codes read in the OBDII cars? Related question; Is the lamp missing in the gauge cluster, or just not used? Would be nice to have the lit indicator when activated.
Glenn
Old 08-10-2010, 05:26 AM
cdvs cdvs is offline
Originally Posted by RojoRocket View Post
...2) I also have a question regarding the "Power" lamp in the dash, missing in this MY. How are the trouble codes read in the OBDII cars? Related question; Is the lamp missing in the gauge cluster, or just not used? Would be nice to have the lit indicator when activated.
Glenn
Interesting question. Our '96 has no transmission info available through the OBDII interface. TCU codes are read the same way as OBDI. Are you sure the power light is deleted in your '97?
Old 08-10-2010, 07:59 AM
Old Fogey
cdvs,
Reading back through this thread I see numerous references to "no power light" from owners of OBDII cars. I lack a '97 Service Manual, so have no true documentation to be certain. Waiting for some more folks to chime in on this. I know I have no power lamp lighting at start-up or when activated by the newly installed switch.
Glenn
Old 08-10-2010, 10:38 AM
NeedForSpeed NeedForSpeed is offline
Glenn
That was a fun day, the second mini-Roseville meet
While I was working on Blackberry, Glenn had his clay bar out and went to work on Road Warrior, my 92 Pearl LS-L.
We were both thrilled at how both cars turned out
Now, what about that missing POWER light, how are TCU codes read in OBDII cars?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 08-10-2010, 12:06 PM
I've expressed what I know about our '96, an OBDII. Perhaps the '97s are different. If so, we'll have to be more carefull in how we ask the question.
Old 08-10-2010, 12:24 PM
So, when you key the car, and the lights come up, you have a green POWER light?
Checking codes on your 96 uses the POWER light, just like early cars?
Old 08-10-2010, 01:01 PM
I tried to be careful with my wording, because the car wasn't here to check. Now, it is. There is no power light, but the codes are read the same way. The ATF temp light flashes instead of the power light. Have fun!
Old 08-10-2010, 01:19 PM
Another mystery solved, learn something NEW about these cars everyday
Now its time to see what [if anything] happens when the gauge cluster is swapped for an earlier one
OR, to see if the the power bulb is missing and taped over,
OR, even if the stencil is there,
OR, OR,,,,
