Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #151
Old 07-17-2007, 12:30 PM
cdigerlando cdigerlando is offline
ARP Bolts
Originally Posted by SVXRide
Here!
-Bill (who has the ARP worksheet, just doesn't have the time to fill it out )
The worksheets are all filled out for the head bolts and the mains. I'll post them in my locker if anyone wants to check my measurements. I used a very accurate vernier caliper, but measuring stuff like the depth of the thread from the bottom of the hole was difficult. I don't think that is going to be too critical though.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 07-17-2007, 12:36 PM
Mike, I'll probobly go with a set of ARP head bolts if we can get them in time... Otherwise I think the stockers will hold a bunch of boost
Old 07-19-2007, 09:42 AM
ARP Bolts
I still have not gotten any response from ARP. I mentioned that ECUtune would want to distribute the SVX Kit. I may call ARP this afternoon and bug them again. I hate to be the squeeky wheel, but you know what they say. Main bolt availibility is a critical path item for me right now. I just need to know if they are going to provide these or not, so I can get my honing done. The Cometic Gasket manufacturer also recommended using ARP head bolts, so before I order the cometic gasket I would like to find out about the head bolts.
Chuck D.
Old 07-19-2007, 01:07 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Chuck,
Could you please email them to me -- william.e.cutlip@nasa.gov
Thanks.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-19-2007, 02:38 PM
Locker
Chuck,
Thanks.
-Bill
If you don't mind, I'm going to wait and try to figure out how to post them in my locker. For some reason I have been unable to upload stuff there. Besides, it will really bog down your e-mail.
Chuck D.
Old 07-19-2007, 02:43 PM
Arp
Well I tried to get ahold of Chris R. from ARP to discuss the status of the bolts. He was off giving a plant tour. If I don't hear from him by Friday, I'm ordering new block bolts from Subaru. If they still want to step up and provide head bolts, I'll try to get that worked out. Just kind of pisses me off I wasted my time measuring this stuff so carfully.
Chuck D.
Old 07-19-2007, 04:12 PM
longassname's Avatar
Just some dude.
I'll take care of getting them to spec and quote head studs. The count as I have it is...
Chuck wants them
Bill do you definitely want them?
Tom maybe wants them
Is this correct?
And chuck wants block bolts as well
Old 07-19-2007, 05:49 PM
mikecg's Avatar
mikecg mikecg is offline
Throw me on the list too. Hopefully I'll be able to cough up some money for them.
Old 07-19-2007, 06:17 PM
Just some dude.
head count so far............
Head studs:
Chuck
Mike
Bill?
Tom maybe
Block bolts:
Chuck
Old 07-19-2007, 08:19 PM
ARP Head and Main bolts.
Yes I wanted both, provided they can provide sealing from the coolant jacket to the crankcase. Hopefully they will respond better to you. Have they contacted you? I gave them the name of your website on my last e-mail.
Thanks
Chuck D.
Old 07-19-2007, 08:26 PM
SVXRide's Avatar
Chuck wants them
Is this correct?
Michael,
yep, as long as they'll come with nuts that will seal. I'm also interested in studs for the block.
-Bill
p.s. Chuck - remember that the lockers are going away tomorrow...
Old 07-19-2007, 09:29 PM
Mike... it all depends on when we can have them... I could be in for 2 sets of head bolts but for now lets lock down on one
Old 07-20-2007, 12:53 AM
Just some dude.
Tom, I'm sure they won't have them in time for Robert's motor.
Bill the block bolts would be bolts.
Head studs:
Chuck
Mike
Bill
Block bolts:
Chuck
Bill
Old 07-20-2007, 05:20 AM
Lockers
I did not know that. Thanks
Chuck D.
Old 07-20-2007, 01:17 PM
Arp
OK. ARP got back with me. Mike will be happy to know that they make main bolts (not studs) for the engine. They have the 12 large size and the 2 small size main bolts. They also have casing seals(10) and washers (4) for them. They also make casing bolts, but I did not get into that with him since he seemed a little impatient as it was putting together such a small kit. Casing bolts are kind of overkill anyway IMHO.
The head bolts are another story. They have the large bolts from the EJ series kits. The small bolts are going to be tricky. He is going to send me something to try out, but they may be too long. I'll check to see if there will be any problems using them.
Just got the prices which are steep. Check this out
"We have the mains covered, on the head studs you may want to do test fit.
Head Stud;
ATP7.700-2LUGB, ARP2000 stud $16.98 each
APN12-1, 12pt nut $1.86 each
APW995N, Washer $0.57 each
Main Bolt;
M12AM6.215-4, INCONEL Main Bolt $39.25 each
M12AM4.175-4, INCONEL Main Bolt $38.08 each
11034-AMWS, Seal Washer $5.35 each
AMWC750 $1.11 each
The main bolts are components that are in our 4 cyl. kits.
All these prices are jobber price level."
That's $605.10 for the mains and $310.56 for the Head studs which may not work. Still interested Bill? Actually the price on the main bolts is reasonable compaired to other bolt kits for the WRX (which match up to the EG33), but frankly I had no idea they were so expensive. I think I will just go with the head studs only and go factory with the mains. They are reasonable.
I also mentioned that Mike wanted to distribute these through ECUtune.
I'm going to see if they will ship me a single stud to see if it works in the other locations. I'll keep you posted.
Chuck D.
Chuck D.
